POV-Ray : Newsgroups : povray.programming : [BUG] POVRay excessive memory consumption Server Time
28 Sep 2024 22:14:25 EDT (-0400)
  [BUG] POVRay excessive memory consumption (Message 1 to 10 of 55)
Subject: [BUG] POVRay excessive memory consumption
Date: 24 Jan 2004 09:07:30
Message: <40127c21@news.povray.org>
While working on a partial image reading patch, I came accross the
following bug in POVRay:
In jpeg_pov.cpp, around line 405, the code reads:
-------------------<jpeg_pov.cpp:405>---------------------------------
        bufptr->row_stride = w * 3;
        bufptr->row_pointer[0] = (JSAMPROW)POV_MALLOC(
                bufptr->row_stride * w, "JPEG line buffer");
And some lines below:
-------------------<jpeg_pov.cpp:636>---------------------------------
        /* JSAMPLEs per row in output buffer */
        bufptr.row_stride =
                bufptr.cinfo.output_width * bufptr.cinfo.output_components;
        /* Make a one-row-high sample array */
        bufptr.row_pointer[0] = (JSAMPROW)POV_MALLOC(
                bufptr.row_stride * width, "JPEG line buffer");
Both chunks of code contain the same stupid bug which causes excessive
memory consumption:
row_stride is the amount of memory in bytes needed for one ROW in the
image. What is being done here is allocating this amount of memory for
EVERY ROW in the image.
This means that for bpp bytes per pixel, we end up allocating
   width*width*bpp bytes
where only
   width*bpp bytes
are needed! [In my case that meant 768Mb instead of 50kb.]
Please apply the following patch:
                bufptr->row_stride, "JPEG line buffer");
        bufptr.row_stride =
                bufptr.row_stride, "JPEG line buffer");
This modification (effectively removing the with multiplication in the
memory allocation size calculation) has been verified to work correctly
by me. Note that row_pointer[0] is always only meant to contain one
single image row, never more.
Wolfgang
I hope I can have a look at POVRay's next beta version (linux source
code) real soon.
Subject: Re: [BUG] POVRay excessive memory consumption
Date: 24 Jan 2004 09:42:03
Message: <slcae1-9jo.ln1@triton.imagico.de>
You'd probably save some time if you wait until 3.6 is out because
otherwise you would need to rewrite the code (image reading/writing has
not changed much but some changes require modifications at a lot of
places in the code).
Sounds logical to me although i have no experience with libjpeg.
Just in case this is not clear to everyone - this is not a memory leak,
it is just POV-Ray temporarily allocates more memory than it needs.
> code) real soon.
As usual source will not be available during beta.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 24 Jan 2004 10:39:29
Message: <401291b0@news.povray.org>
Well, I really see your point but I am actually very tired of _waiting_.
If anybody out there is waiting for the POVRay team to do just the smallest
thing, he'd better invest in finding the fountain of youth ;)
BTW, what about including this patch into POVRay-3.6?
Basically, the patch allows you to select a rectangular region of
an image_map so that only this part is read in and stored in RAM.
Pixels outside this region are all considered 50% gray (some other
solution like quick_color could also be thought of).
Of course, inclusion only makes sense if there are more people
interested in it. I am currently using it to render MARS images,
because I cannot fit all the 2.4 Gb topo & color into RAM.
Correct.
>> code) real soon.
It may or may not make sense to publish source code of beta versions.
But as I am sombody who actually works with the code, has already found
several bugs, suggested fixes for most of them and is actively writing
patches for POVRay, it may make sense to let me join the group of people
who may view the current development code.
Wolfgang
Date: 24 Jan 2004 11:12:52
Message: <q4iae1-afd.ln1@triton.imagico.de>
Well i only suggested you might *save* time by waiting.
As Chris Cason has mentioned in the status report 3.6 does not introduce
significant new features in the core functionality.
I don't think this would be a very useful patch - selecting and copying
a rectangle from a larger image is the task for an external program,
what would be really useful would be a patch that adaptively loads those
parts on an image into memory that are actually used - without the need
to specify a rectangle and that also unloads those parts that are no
more needed during render progress to free space for new parts.  Of
course such a feature would not only be useful for images but also for
meshes for example.  AFAIK some other raytracing programs also have such
a feature.
This is of course no way my decision but to be frank - it does not seem
to me that you propose to be allowed source access primarily to fix
bugs, this is perfectly possible with the 3.5 code and some of your
proposals have already been included in 3.6 (and the last two probably
will be as well).
Date: 24 Jan 2004 11:58:07
Message: <cjameshuff-DF63BC.11584024012004@news.povray.org>
In article <401291b0@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
It's too late for that. Public betas are already starting, the only
things that will go into POV from now until the 3.6 final release are
bug fixes. The over-allocation fix might get in, but no new features or
major changes.
Pixels outside that region should probably be fully transparent, to be
consistent with the "once" option. And why not read in the region as the
entire image, filling the entire area of the image_map? Simpler, and
avoids the above problem completely.
http://tag.povray.org/
Date: 24 Jan 2004 12:11:54
Message: <4012a759@news.povray.org>
...which is perfectly acceptable (to me).
Yes, but there are two reasons for my approach:
(1) Opening a 1Gb file in an external program, selecting some part,
    saving it... all that for every view port is too much work for me.
(2) The cut-down chunk needs extra calculations to make sure the
    image map projection is exactly correct.
My patch saves me from both these.
Still it is probably a very special thingy and of little use for
most people.
> a feature.
I actually had the plan to implement something like that for meshes
before I came accross the possibility using the isosurface for the topo.
In-memory (de)compression of the data was another approach I thought of.
> will be as well).
But...
I was told the same argument some time ago. It read like "we did a
complete rewrite of unix.cpp but you can do everything with the old
version so feel free to send us patches for the old code".
I could consider that as an expression of no interest in what other
people are doing. It's a bit like preaching water and drinking wine.
Don't you think that this effectively hinders futher development?
It makes me waste time writing patches for old code which have to
be converted to the new code. It makes the POVRay team waste time
getting patches based on one-year old code base. And finally, most
of the bugs I see come from looking at the source, not from using
a binary.
Don't understand me wrong: I respect any decision the POVRay team
makes.
But I see a further possibility using the following roadmap:
(1) get povray 3.6 out
(2) bring out long awaited new megapov based on 3.6
(3) more frequent megapov updates
In this case I'd be more happy to see current megapov development
and to be able to write patches for (or even contribute to) megapov
[than to mainline povray] anyways.
To me (as looking at it from outside) it seems like there would be
enough ideas, code and manpower around here for quite some innovation
but there is somebody somewhere out there actively pulling the break.
I learned that in most cases it turns out negatively to hinder those
people who want to work (and have the ability to do it well) from
doing their work.
Wolfgang
Date: 24 Jan 2004 12:12:54
Message: <4012a796@news.povray.org>
In article <401291b0@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
Well, then  start your own ray-tracer project.  Oh, well, wait, every single
one ever started has died about as quickly.  Quality software development
takes time, otherwise you would end up with bloated junk and broken 1.0
designs!  For example Mozilla is a great example for a design broken from
the beginning...
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Jan 2004 12:13:23
Message: <4012a7b3@news.povray.org>
This ain't a patch, this is a trivial bug fix!
    Thorsten
Date: 24 Jan 2004 12:19:13
Message: <4012a910@news.povray.org>
I would prefer the pixels to be of configurable color...
I do not completely understand what you plan there but it seems to me
that this requires the used to do additional scaling and
rotation/translation of the texture (which may not be trivial for
some projections).
Furthermore, for my current personal use, the 50% gray is a "feature"
(sea level on Mars).
Wolfgang
Date: 24 Jan 2004 12:24:01
Message: <4012aa31@news.povray.org>
I was talking about the partial image reading.
Wolfgang
