POV-Ray : Newsgroups : povray.programming : [bug] Non-critical: ALPHA handling in parser Server Time
11 Jul 2026 09:36:11 EDT (-0400)
  [bug] Non-critical: ALPHA handling in parser (Message 1 to 1 of 1)
Subject: [bug] Non-critical: ALPHA handling in parser
Date: 24 Jan 2004 09:06:43
Message: <40127bf2@news.povray.org>
I found a non-critical bug in parstxtr.cpp around line 479:
The code reads:
-------------------<parstxtr.cpp:471>---------------------------------
     CASE (OFFSET_TOKEN)
       Parse_UV_Vect (Image->Offset);
       Image->Offset[U] *= (DBL)-Image->iwidth;
       Image->Offset[V] *= (DBL)-Image->iheight;
     END_CASE
     CASE (ALPHA_TOKEN)
       Warning(155, "Keyword ALPHA discontinued. Use FILTER instead.");
     CASE (COLOUR_KEY_TOKEN)
       switch(Token.Function_Id)
          case FILTER_TOKEN:
            EXPECT
              CASE (ALL_TOKEN)
This does not work as expected: ALPHA_TOKEN will never get selected
because putting "alpha" into an image_map will result in COLOUR_KEY_TOKEN
getting parsed instead. Please apply the following patch to fix that:
     CASE (OFFSET_TOKEN)
     END_CASE
          case ALPHA_TOKEN:
            break;                               <-- (***)
          case FILTER_TOKEN:
            EXPECT
              CASE (ALL_TOKEN)
The break; statement in the line marked with (***) can be left away
if "alpha" can be parsed like "filter". Otherwise one should at least
parse (and ignore) the argument for "alpha".
Cheers,
Wolfgang
