POV-Ray : Newsgroups : povray.programming : Compiling Pov-Ray and a suggestion: Server Time
16 Dec 2025 05:04:43 EST (-0500)
  Compiling Pov-Ray and a suggestion: (Message 1 to 9 of 9)
Subject: Compiling Pov-Ray and a suggestion:
Date: 21 Jan 2004 05:46:43
Message: <400e5893$1@news.povray.org>
This refers mostly to Windows version using Visual C++ 6.0 with Intel
C++ Compiler.
1. What is the procedure POV-Team uses to generate profiling data for
pvengine.exe using Intel C++ Compiler? Do you simply run benchmark.pov
(or some simpler scene) once and use that data?
2. Since speed is of essence and some people just want to change (say)
the Windows editor, it would be a nice option, if the editor and the
POV-Ray engine itself could be compiled separately as not everyone can
use the fastest compilers. Speed differences in editor usually don't
matter at all.
Severi Salminen
Subject: Re: Compiling Pov-Ray and a suggestion:
Date: 21 Jan 2004 05:59:33
Message: <gdms009b6jsmrrvtmc2sotv0b0oe7qjnfn@4ax.com>
On Wed, 21 Jan 2004 12:46:43 +0200, Severi Salminen
> matter at all.
Note POV-Ray for Windows is threaded application with prorities for threads
and "Duty Cycles" so you can adjust time your CPU use for rendering. And you
can not use editor at all and use only Queue feature for rendering scenes
taken from other editors. And you still have possibility to create custom
config.h and compile core source without GUI with your Intel C++. Creation of
config.h should be simple from technical point of view ;-)
ABX
Date: 21 Jan 2004 06:20:39
Message: <400e6087$1@news.povray.org>
>>matter at all.
I think I was not clear enough. I meant that there might be people, who
want to make changes to the source code of the _editor_ (not the engine)
and compile it and use it - without losing the optimizations of the
engine itself. This is possible only if they have the Intel Compiler.
Now they allways have to compile the engine together with the editor and
the rendering speed might suffer if they don't have the Intel Compiler.
If the editor could be separated, there would be no such issues.
Severi Salminen.
Date: 21 Jan 2004 06:54:01
Message: <rdps009e0rkhak991fnka5te1te4g5bur9@4ax.com>
On Wed, 21 Jan 2004 13:20:39 +0200, Severi Salminen
You mean codemax? AFAIK Codemax is enclosed within separated DLL so...
ABX
Date: 21 Jan 2004 07:14:11
Message: <400e6d13$1@news.povray.org>
No, I mean Intel C++ Compiler (see the link) that can be used within
Visual C++ 6.0 and that is the compiler POV-Team uses to get the fastest
binaries for Windows. Other compilers produce (usually) a bit slower
code - (allthough my chess engine was faster with plain VC 6.0 without
Intel). If the editor was a separate executable, then someone could make
changes to the editor and compile it with some other compiler without
affecting the engine optimizations. Now it is impossible.
http://www.intel.com/software/products/compilers/windows/
(I don't know what you meant by Codemax)
Severi S
Date: 21 Jan 2004 07:37:05
Message: <u3ss00hssu5mrk2cbcstv0qieeucabgfmu@4ax.com>
On Wed, 21 Jan 2004 14:14:11 +0200, Severi Salminen
Sorry, I wasn't precise. I know what Intel C++ Compiler is :-) Codemax is a
name of editor component used in POV-Ray for Windows GUI. It isn't linked with
POV-Ray, it exists in separated DLL. Just rebuild that DLL with your changes
and work with new features and the same raytracer. I did not tested it thought
I have worked without editor in the past so it is already well separated (see
section "1.10.8.2.4.1  Use Editor" in manual).
ABX
Date: 21 Jan 2004 07:38:24
Message: <8hss00degp09pdu5bo50720ae8sbq05mhv@4ax.com>
On Wed, 21 Jan 2004 13:35:13 +0100, ABX <abx### [at] abxartpl> wrote:
> It isn't linked with POV-Ray
I meant, it is linked dynamically.
ABX
Date: 21 Jan 2004 07:56:36
Message: <ghts005rfipa0hl1hspsip1tti8q3i1gfu@4ax.com>
Out of curiosity, do you mean anything specific here ?
http://www.povray.org/download/features/wishlist.php
ABX
Date: 21 Jan 2004 10:15:51
Message: <400e97a7$1@news.povray.org>
a
with
changes
thought
(see
If that is the case, then I take my words back. But I'm still confused. I
made same minor alterations to editor code and it really produces only one
single pvengine.exe file that includes everything - not a separate DLL. Or
are we using the words "editor" and "GUI" differently? Maybe I'm talking
about the GUI instead of the editor. Is the editor in separate DLL and GUI
and POV-engine in the same executable?
Here is  my goal:
I just wanted to see the current pps (pixels per second) readout every
second or even after drawing every row. Normally it shows the reading only
if the last line took longer than 9 secs to render. I want to see it all the
time - I don't mean the total average readout at lower right corner. I only
removed the if-condition from the sources (I don't remember the exact file
now) and recompiled. It obviously produced only pvengine.exe.
If I'm really talking about GUI, then: it would be a nice option, if the
_GUI_ and the POV-Ray engine itself could be compiled separately.
I hope it went right this time ;-) It's a pity I'm now on a different
computer so I can't test this. I really tried it only one time so there are
good changes that I missed something :)
Severi S.
