POV-Ray : Newsgroups : povray.programming : [patch] Press mouse with +P Server Time
1 Apr 2026 23:51:42 EDT (-0400)
  [patch] Press mouse with +P (Message 1 to 3 of 3)
Subject: [patch] Press mouse with +P
Date: 29 Nov 2003 07:31:22
Message: <3fc89199@news.povray.org>
Here we go again...
Christoph Hormann wrote:
>I did not completely understand your description, does this also fix the
>problem that when you close the render window with a mouse click after
>completition (with the +p option) the mouse event is passed to whatever
>is behind the window?
This is a separate patch for the mouse press bug as described above:
Modified in unix.cpp:
Add ButtonReleaseMask to the event mask:
#define theEVENTMASK  (ButtonPressMask      | \
                       ButtonReleaseMask    | \
                       KeyPressMask         | \
                       ExposureMask         | \
                       StructureNotifyMask)
Make button release quit POVRay (instead of button press):
This is to replace the "case ButtonPress:" label in HandleXEvents():
      case ButtonPress:
    #if (X11_DEBUG > 0)
            Debug_Info("ButtonPress\n");
    #endif
        if(!finished)
             * If not finished, a button click will cause a window refresh.
            refresh_x_min = 0;
            refresh_y_min = theCurrY;
            refresh_x_max = Frame.Screen_Width;
            refresh_y_max = theCurrY + 1;
            refresh = True;
        break;
      case ButtonRelease:
    #if (X11_DEBUG > 0)
            Debug_Info("ButtonRelease\n");
    #endif
        if(finished)
           /* If finished, a button release will quit.*/
           abortRender |= finished;
        break;
I will not post the complete function here because it is too long.
Wolfgang
Subject: Re: [patch] Press mouse with +P
Date: 1 Dec 2003 08:02:12
Message: <3FCB3BD4.3050601@free.fr>
	Thanks for this !  The patch has been tested and applied.
	You're welcome to find some more  :-)
	- NC
Date: 3 Dec 2003 12:42:59
Message: <3fce20a2@news.povray.org>
When I have the time...
Are there any bug reporst as a hint for where to look for?
Wolfgang
