POV-Ray : Newsgroups : povray.programming : Re: Point cloud to mesh Server Time
12 Jul 2026 12:08:45 EDT (-0400)
  Re: Point cloud to mesh (Message 1 to 1 of 1)
Subject: Re: Point cloud to mesh
Date: 22 Aug 2003 08:28:15
Message: <3f460c5f@news.povray.org>
Hello,
RetroJ wrote:
>     I wonder if anyone can point me toward an algorithm for creating a
> triangle mesh from a group of points.  The project is to render a
> landscape, so I assume up front that there will be no overlap in the
> elevation axis.
as Warp already pointed out, generating triangles from a set of points
is not an easy task and subject to current research. However, it might
be feasible in your special case. I would try the following:
- project the points in the plane
- make a Delaunay triangulation
- set the correct elevation
If the result is not good enough, I'm sure we can think of something
else.
Greetings
Follow-Up set to povray.advanced-users
aaa := ira
Date: 2 Sep 2003 16:10:01
Message: <web.3f54f80dc5a11fef5a8719ab0@news.povray.org>
I found the following:
http://www.pulsar.nl/gpt/epac02/wepri059.pdf
http://3dk.asu.edu/archives/publication/g3dk/IASTED-398-064.pdf
http://www.comp.nus.edu.sg/~indri/research.htm
http://www-dsp.com.dist.unige.it/~charlieb/docs/icav3dc01.pdf
http://www.lec.leeds.ac.uk/~jason/Mesh_Generation/
.....this last one has a lot of mesh-generating info.
Hope it helps......
Thomas Willhalm wrote:
>Hello,
>> elevation axis.
>else.
>Greetings
>Thomas
>aaa := ira
