POV-Ray : Newsgroups : povray.programming : Re: Pains in rendering complex polygons Server Time
15 May 2026 15:46:53 EDT (-0400)
  Re: Pains in rendering complex polygons (Message 1 to 10 of 14)
Subject: Re: Pains in rendering complex polygons
Date: 27 Jul 2003 19:36:44
Message: <3f24620c@news.povray.org>
Jake McDowell <McN### [at] techiecom> wrote:
>     dSpline(blah),
  You don't need a comma there.
Date: 28 Jul 2003 01:15:35
Message: <G8iNxGAT7KJ$EwOO@econym.demon.co.uk>
>>     dSpline(blah),
Alternatively you could move the comma so that it comes before the
dSpline(blah) and remove the hard-coded one after the 80.
polygon {
  80
  #declare blah=80;
  #while(blah>0)
    ,dSpline(blah)
    #declare blah = blah-1;
There are some situations where commas are required and that trick
doesn't work (I can't think of a situation off hand, but I've met one in
the past). In such a case you could process the first or last item
outside the loop
polygon {
  80,
  dSpline(80)           // out of loop, no comma
  #declare blah=79;
  #while(blah>0)
    ,dSpline(blah)
or put an #if statement round the comma.
polygon {
  80,
  #declare blah=80;
  #while(blah>0)
    dSpline(blah)
    #if (blah > 1) , #end
Mike Williams
Gentleman of Leisure
Date: 28 Jul 2003 02:19:47
Message: <3F24C082.6090807@Techie.com>
>>>    dSpline(blah),
> polygon {
>   80
>   #declare blah=80;
>   #while(blah>0)
>     ,dSpline(blah)
>   #end
> outside the loop
> polygon {
>   80,
>   #declare blah=79;
>   #while(blah>0)
>     ,dSpline(blah)
>   #end
> polygon {
>   80,
>   #declare blah=80;
>   #while(blah>0)
>     dSpline(blah)
>   #end
w00t !!!  yes !  you rock... can you tell i'm not quite used to the
povray way of doing things ?  :]
thank you a load... your information/help here is tremendously valuable
to me... i knew there was a simple way of doing this !
Date: 3 Aug 2003 15:48:07
Message: <3f2d66f7@news.povray.org>
  Why do it the hard way when you can simply omit the comma?
Date: 3 Aug 2003 19:35:28
Message: <M$J$BAA2wZL$EwOy@econym.demon.co.uk>
Omitting the comma happens to work for this particular case, but there
are similar situations where commas are required. It might be useful to
be prepared.
Mike Williams
Date: 4 Aug 2003 04:48:36
Message: <3f2e1de4@news.povray.org>
  Can you cite an example?
Date: 4 Aug 2003 05:56:53
Message: <04bsivobl3m0omh1leh6mc2i0i2hr9a4dh@4ax.com>
At least commas are necessary in parts of function parser. Below example does
not work without commas.
#local Params=2;
#local F=array[5];
#local F[0]=function(a){0};
#local F[1]=function(a,b){0};
#local F[2]=function(a,b,c){0};
#local F[3]=function(a,b,c,d){0};
#local F[4]=function(a,b,c,d,e){0};
#macro Do(c)
  //#if(c>0),#end  /* <-- uncomment this line to make it working */
  c
#local f=F[Params-1];
#local my_f=function{f(#local C=0;#while(C<Params)Do(C)#local C=C+1;#end)};
ABX
Date: 4 Aug 2003 12:02:51
Message: <cjameshuff-B41606.11011004082003@netplex.aussie.org>
In article <3f2e1de4@news.povray.org>, Warp <war### [at] tagpovrayorg>
Anything that has an expression starting with an operator, such as "-x".
polygon {Foo
    Foo
    -Foo2
    Bar
The point list will be interpreted as "Foo - Foo2, Bar".
This kind of error can be very difficult to track down. I *always* use
commas, and always use logic which puts them where they are needed.
http://tag.povray.org/
Date: 4 Aug 2003 15:43:50
Message: <3f2eb776@news.povray.org>
> polygon {Foo
>     Foo
>     -Foo2
>     Bar
  I was talking about lists of parameters created with #commands (#whiles
etc).
  Anyways, if you want to be sure, you can simply write (-Foo).
Date: 4 Aug 2003 16:16:13
Message: <cjameshuff-FBC497.15143404082003@netplex.aussie.org>
In article <3f2eb776@news.povray.org>, Warp <war### [at] tagpovrayorg>
> etc).
And this is still relevant in that case:
#if(Foo)
    -Point
#else
    Point
Or you could just use the comma where the syntax specifies one.
