POV-Ray : Newsgroups : povray.programming : Parametric object with shadow gets black Server Time
11 Jul 2026 12:38:30 EDT (-0400)
  Parametric object with shadow gets black (Message 1 to 5 of 5)
Subject: Parametric object with shadow gets black
Date: 21 Jun 2003 12:14:09
Message: <3ef48451@news.povray.org>
The patch below should fix the problem related to the no_shadow
and parametric objects reported in povray.general
Message-ID: <3ef375c0@news.povray.org>
Subject: Re: Parametric object with shadow gets black
Newsgroups: povray.general
Date: Fri, 20 Jun 2003 22:59:01 +0200
HTH Massimo
--- obj/fpmetric.cpp 2003-06-21 17:56:52.000000000 +0200
+++ src/fpmetric.cpp 2003-06-21 17:08:17.000000000 +0200
@@ -447,7 +447,7 @@
- if (TResult < Depth2)
+ if (TResult < Depth2 && TResult > DEPTH_TOLERANCE)
   Increase_Counter(stats[Ray_Parametric_Tests_Succeeded]);
   VScale(IPoint, Ray->Direction, TResult);
Date: 21 Jun 2003 13:46:12
Message: <3ef499e4@news.povray.org>
Hmm, yes and no.
YES, the image is no longer black and there is a nice shadow
_below_ the parametric object.
And NO, it does not look like the object has any shadow on
its own surface. I mean -- the high parts of the parametric
surface should throw shadows on the low parts...
Or at least if I peak a cylinder through the object.
I failed see such a shadow in my test-renders.
> From: Wolfgang Wieser <.....>
That's me...
Wolfgang
Date: 22 Jun 2003 15:16:20
Message: <3ef60084@news.povray.org>
"Wolfgang Wieser" ha scritto
: YES, the image is no longer black and there is a nice shadow
: _below_ the parametric object.
I saw the shadow below the object, and I thought the surface
was in full light :-(
: And NO, it does not look like the object has any shadow on
: its own surface. I mean -- the high parts of the parametric
: surface should throw shadows on the low parts...
: Or at least if I peak a cylinder through the object.
: I failed see such a shadow in my test-renders.
Looking at the code (All_Parametric_Intersections) it seems that
only one intersection is pushed onto the Depth_Stack, so when
testing for self shadows if the first intersection is the starting
point, not meaningful (and so dropped with my patch), every other
intersection is not considered.
I just gave a fast glance to docs and code, so I cannot say whether
this behaviour is the documented behaviour or a misbehaviour.
I don't think a quick patch is easy, but, may be, it suffices a loop.
Massimo
Date: 23 Jun 2003 16:18:02
Message: <3ef7607a@news.povray.org>
"Massimo Valentini" ha scritto
: I don't think a quick patch is easy, but, may be, it suffices a loop.
Instead of a loop it is possible to set appropriately the range
for intersections, so that the first is the correct.
The following patch should fix the shadow problem, though not
the accuracy one.
Massimo
--- obj/fpmetric.cpp 2003-06-23 22:10:24.000000000 +0200
+++ fpmetric.cpp 2003-06-23 22:11:30.000000000 +0200
@@ -222,6 +222,9 @@
  if (Depth1 == Depth2)
   Depth1 = 0;
+  if (Depth1 < DEPTH_TOLERANCE)
+    Depth1 = DEPTH_TOLERANCE;
  if ((Depth1 += 4 * Par->accuracy) > Depth2)
   return false;
Date: 25 Jun 2003 17:30:48
Message: <3efa1486@news.povray.org>
Hey, that's cool! It seems to work well. There is lots of self-shadow
and the whole object throws shadow. AND it is no longer solid black.
Does anybody know if there is any reason for doing
>    Depth1 = 0;
around line 222?
Shouldn't one use
    if(fabs(Depth1-Depth2)<=some_epsilon)  Depth=0;
instead?
> though not the accuracy one.
The accuracy problem is caused by the array index overflow.
I don't know what one should do. Of yourse, one could dynamically
enlarge the array but before doing that one should be certain
that the loop will ever terminate in all situations.
I mean -- this is FP numerics and I'm not sure if we can trap
situations where things break (no convergence...).
I'm not sure about that (no time to study the code in depth) but
it is possible that there is no emergency break in the code which
makes sure that we give up numeric calculation when it comes clear
that the desired accuracy cannot be reached? Trying to reach
1e-20 accuracy with standard FP is simply ridiculous...
Wolfgang
> @@ -222,6 +222,9 @@
>    return false;
