POV-Ray : Newsgroups : povray.programming : Suggesting trivial patch. Server Time
2 Apr 2026 01:30:47 EDT (-0400)
  Suggesting trivial patch. (Message 1 to 5 of 5)
Subject: Suggesting trivial patch.
Date: 21 May 2003 16:45:07
Message: <3ecbe552@news.povray.org>
The images look nice but I got the following warning from POVRay:
Warning: The maximum gradient found was 0.000, but max_gradient of the
isosurface was set to 0.000. The isosurface may contain holes!
Adjust max_gradient to get a proper rendering of the isosurface.
Looking at isosurf.cpp, I suggest that we replace "%f" with "%g" or
similar.
Wolfgang
The isosurfaces with such a little gradient can be seen here:
http://www.cip.physik.uni-muenchen.de/~wwieser/
Subject: Re: Suggesting trivial patch.
Date: 22 May 2003 14:39:02
Message: <3ecd1946$1@news.povray.org>
In article <3ecbe552@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
> similar.
Why?
    Thorsten
e-mail: tho### [at] trfde
Date: 22 May 2003 19:09:22
Message: <3ecd58a2@news.povray.org>
>> similar.
> Why?
  So that instead of getting "0.0000" we get something like "1.23e-6"?
Date: 23 May 2003 09:16:07
Message: <3ece1f17@news.povray.org>
In article <3ecd58a2@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Hmm, now I see your idea behind this.  Unfortunately this won't really work
because in effectively anything below 0.0000 is pretty much below the
precision threshold you can reach with double precision floating-point
numbers for the number of calculations performed by isosurfaces.
I will see if I can come up with something intelligent to at least make the
message not show up in such case.
    Thorsten
Date: 23 May 2003 15:00:49
Message: <3ece6fe0@news.povray.org>
> work because in effectively anything below 0.0000 is pretty much below the
My experience show that you actually CAN render isosurfaces with a gradient
of less than 0.000 .
The actual output is limited to 3 digits after the decimal point, not 4.
Using something like %g would be appreciated.
> the message not show up in such case.
No, NOT writing the message is probably a bad idea. Because in my case
a gradient of 0.01 already takes ages to render and I a using values
of 0.0002 and the like.
Wolfgang
