POV-Ray : Newsgroups : povray.programming : animation? Server Time
2 Apr 2026 01:38:55 EDT (-0400)
  animation? (Message 1 to 8 of 8)
Subject: animation?
Date: 18 Apr 2003 16:11:24
Message: <3ea05bec@news.povray.org>
I am using that code... I just copy and past it from the documentation.
There is no animation... why?
    location <0, 3, -6>
    look_at <0, 0, 0>
  light_source { <20, 20, -20> color White }
  plane {
    y, 0
    pigment { checker color White color Black }
  sphere {
    <0, 0, 0> , 1
      gradient x
      color_map {
        [0.0 Blue  ]
        [0.5 Blue  ]
        [0.5 White ]
        [1.0 White ]
      scale .5
    rotate <0, 0, -clock*360>
    translate <-pi, 1, 0>
    translate <2*pi*clock, 0, 0>
Subject: Re: animation?
Date: 18 Apr 2003 16:34:27
Message: <3ea06153@news.povray.org>
You are probably just rendering a single frame, look into the
documentation somewhere under ini options or animation on howto render a
series of frames with the clock value going from 0 to 1. You then need
some video encoding saftware to make an animation from that.
Date: 18 Apr 2003 16:43:09
Message: <3ea0635d$1@news.povray.org>
it says
Now, at last, with POV-Ray 3, there is a better way. We no longer need a
separate batch script or external sequencing programs, because a few simple
settings in our INI file (or on the command line) will activate an internal
animation sequence which will cause POV-Ray to automatically handle the
animation loop details for us.
O.K. I think problem is my INI settings but which INI file. There are lots
of...
"Simon Adameit" <sim### [at] gaussschule-bsde>, haber iletisinde sunlari
yazdi:3ea06153@news.povray.org...
Date: 18 Apr 2003 16:48:12
Message: <3EA0648B.A29061C1@gmx.de>
Could you please ask such things in a different group?  Preferably in
.newusers.  This group is for POV-Ray source code related discussion.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 18 Apr 2003 17:06:23
Message: <3ea068cf$1@news.povray.org>
> it says
> of...
You can make your own ini file, there you just specify your *.pov as
input file and set the options you want(you should turn jittering of aa
off for animation) or you set the options at the command line(in the
windows version there is a text field to do that).
Date: 18 Apr 2003 18:30:19
Message: <3ea07c7b@news.povray.org>
Sure Christoph.
Actually I will from now on..
Do the people here also read there???
Date: 18 Apr 2003 19:38:30
Message: <3EA08C96.49423913@pacbell.net>
> Sure Christoph.
The people that will best be able to help you read that group.
Ken Tyler
Date: 22 Sep 2003 08:39:05
Message: <3f6eed69$1@news.povray.org>
In article <3ea05bec@news.povray.org> , "TIMSAH BEYINLI"
This is the wrong group for this question.  This group is for discussion of
the POV-Ray source code.  General questions about using the POV-Ray scene
description language should be asked in either povray.general or
povray.newusers.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
