POV-Ray : Newsgroups : povray.programming : spherical coordinate conventions? Server Time
18 Mar 2026 21:13:40 EDT (-0400)
  spherical coordinate conventions? (Message 1 to 3 of 3)
Subject: spherical coordinate conventions?
Date: 23 Feb 2003 11:16:21
Message: <3e58f3d5$1@news.povray.org>
Hey all,
        There seems to be two different convention for labeling the angles
in sperical coordinates. What I have been taught in school, and have seen in
two different math textbooks is the following: (assuming a right-handed
coordinate system, with z axis pointing up, and the x axis going out of the
page, toward the viewer)
    theta:  angle rotated about the normal, lives in the xy plane, measured
from the x-axis
    phi: angle from the normal, measured from the z axis.
However, in some graphics literature and code, these seem to be reversed.
Will this always be the case? Is there a separate convention in the graphics
world?
Thanks,
George Pantazopoulos
Subject: Re: spherical coordinate conventions?
Date: 24 Feb 2003 16:49:21
Message: <cjameshuff-2E21DE.16453724022003@netplex.aussie.org>
In article <3e58f3d5$1@news.povray.org>,
> from the x-axis
> world?
http://mathworld.wolfram.com/SphericalCoordinates.html
"Unfortunately, the convention in which the symbols [theta] and [phi]
are reversed is frequently used, especially in physics, leading to
unnecessary confusion."
Since computer graphics is closely linked to both physics and
mathmatics, you will probably see a bit of inconsistency.
http://tag.povray.org/
Date: 24 Feb 2003 17:11:38
Message: <3e5a9893@news.povray.org>
> in two different math textbooks is the following: (assuming a right-handed
> the page, toward the viewer)
>     measured
> from the x-axis
Well, in theoretical physics and according to what I have been taught
at university, it is measured in the following way:
theta: measured down from the positive z-axis in range 0...Pi
  (with Pi/2 when it crosses the x-y-plane)
phi: measured (positively/left) around z-axis in the x-y-plane with
  range 0..2*Pi.
x axis: phi=0, theta=Pi/2
y axis: phi=Pi/2, theta=Pi/2
z axis: theta=0, phi=irrelevant
    / sin(theta) * cos(phi) \
r = | sin(theta) * sin(phi) |
    \ cos(theta)            /
The right-handed system: r,theta,phi
(while r,phi,theta is a left-handed system)
[Quoted from memory but pretty sure it is correct.]
HTH,
Wolfgang
