POV-Ray : Newsgroups : povray.programming : Small cleanup of radiosity code Server Time
18 Mar 2026 21:13:40 EDT (-0400)
  Small cleanup of radiosity code (Message 1 to 5 of 5)
Subject: Small cleanup of radiosity code
Date: 10 Jan 2003 14:51:37
Message: <3e1f2449@news.povray.org>
I've been looking at radiosity code recently and remark a few little things
I thought I could share :
Function ra_gather in radiosit.cpp :
- as already noticed we can avoid the call to VUnpack
- in the for() loop there is a
   scale = 1.0;
   VAddScaledEq(Colour_Sums, scale, Temp_Colour);
Hmm ?! Delete the unused variable "scale", and replace VAddScaleEq by
VAddScale
- the trace level and radiosity quality are changed in the for() loop, I
think we can safely move them outside
   opts.Radiosity_Quality = 6;
   #ifdef SAFE_BUT_SLOW
   opts.Quality_Flags = Quality_Values[opts.Radiosity_Quality];
   #else
   /* Set up a custom quality level with no area lights or light buffer */
   opts.Options &= ~USE_LIGHT_BUFFER;
   opts.Quality_Flags &= ~Q_AREA_LIGHT;
   if(!opts.Radiosity_Use_Media)
     opts.Quality_Flags &= ~Q_VOLUME;
   #endif
   /* Go down in recursion, trace the result, and come back up */
   Trace_Level++;
   Radiosity_Trace_Level++;
   for (...) {
   Radiosity_Trace_Level--;
   Trace_Level--;
   opts.Quality_Flags = Save_Quality_Flags;
   opts.Options = Save_Options;
- We can avoid a max3 call if maximum_sample_brightness is not used :
   if(opts.Maximum_Sample_Brightness > 0.0)
     max_ill = max3(Temp_Colour[0],Temp_Colour[1],Temp_Colour[2]);
     if (max_ill>opts.Maximum_Sample_Brightness)
       max_ill = opts.Maximum_Sample_Brightness/max_ill;
       VScaleEq(Temp_Colour, max_ill);
- the inverse of depth is calculated twice (for the gradient and at the end
of the loop), we can replace with
   inv_depth = 1./depth;
   if (depth < opts.Radiosity_Dist_Max * 10.)
     sum_of_inverse_dist += inv_depth;
     sum_of_dist += depth;
     gradient_count++;
     drdxs += dxsquared * Temp_Colour[pRED]   * inv_depth;
   if (depth > opts.Radiosity_Dist_Max)
     depth = opts.Radiosity_Dist_Max;
   Inverse_Distance_Sum += inv_depth ;
all this is certainly negligeable compared to trace() calls but well..
I've also tried to improve the function ot_point_in_node in octree.cpp. It
used to return a long (??) that I replaced by a bool
bool ot_point_in_node(VECTOR point, OT_ID *id)
  DBL sized, minx, miny, minz, lox, loy, loz, hix, hiy, hiz;
  union
    float f;
    long l;
  size;                         /* MUST be float, NOT DBL */
  size.l = id->Size << 23;
  sized = (DBL) size.f;
  minx = (DBL) id->x * sized - OT_BIAS;
  lox = minx - sized * .5;
  if (point[X]<lox) return false;
  hix = minx + sized * 1.5;
  if (point[X]>=hix) return false;
  miny = (DBL) id->y * sized - OT_BIAS;
  loy = miny - sized * .5;
  if (point[Y]<loy) return false;
  hiy = miny + sized * 1.5;
  if (point[Y]>=hiy) return false;
  minz = (DBL) id->z * sized - OT_BIAS;
  loz = minz - sized * .5;
  if (point[Z]<loz) return false;
  hiz = minz + sized * 1.5;
  if (point[Z]>=hiz) return false;
  return true;
The idea is to escape as soon as possible. I don't know if a compiler can do
such an optimisation. Don't expect huge speed up (1% ?). By the way, how to
measure accurately the time (in windows) used by povray ? I get different
render time at each render :(
M
Subject: Re: Small cleanup of radiosity code
Date: 10 Jan 2003 14:59:07
Message: <3e1f260b@news.povray.org>
  I don't want to sound negative, but if a speedup is so small that it
can't be measured, then it's probably not worth.
  If you can say "the rendering was about 20% faster" then it's worth. :)
Date: 10 Jan 2003 15:03:37
Message: <3e1f2719@news.povray.org>
no, no, you're not negative you're pragmatic (and i totally agree with you
M
Date: 10 Jan 2003 16:38:18
Message: <3e1f3d4a@news.povray.org>
If a change, however insignificant as a speedup, does clean up the code
(e.g. VAddScale vs VAddScaleEq), I would vote for it.
Date: 10 Jan 2003 17:01:26
Message: <3e1f42b6@news.povray.org>
In article <3e1f2449@news.povray.org> , "Mael" <mae### [at] hotmailcom> wrote:
Render scenes that take longer!
And take a closer look what other times the Window version reports!!!
    Thorsten
e-mail: tho### [at] trfde
