POV-Ray : Newsgroups : povray.programming : Problems with the sum() and prod(). (Bug in v3.5 ?) Server Time
18 Mar 2026 21:13:39 EDT (-0400)
  Problems with the sum() and prod(). (Bug in v3.5 ?) (Message 1 to 2 of 2)
Subject: Problems with the sum() and prod(). (Bug in v3.5 ?)
Date: 10 Jan 2003 14:05:35
Message: <3e1f197f$1@news.povray.org>
Regarding the problem reported in povray.general (thread with same subject)
it seems to be a bug in the function
void FNCode::compile_seq_op(ExprNode *expr, unsigned int op, DBL neutral)
Changing the line (1298)
 level = max(((int)(level)) - 2, 0) + min(level + 1, 3) + 3;
with:
 level = max(((int)(level)) - 2, 0) + min(level + 1, 3) + 6;
seems to fix. But I'm not sure this is the correct solution, but could
be a starting point.
Massimo
Subject: Re: Problems with the sum() and prod(). (Bug in v3.5 ?)
Date: 10 Jan 2003 15:57:43
Message: <3e1f33c7@news.povray.org>
In article <3e1f197f$1@news.povray.org> , "Massimo Valentini"
> with:
It ain't.  It just hides it.  The problem is far more complex and related to
the way the stack is handled and calculated.
    Thorsten
e-mail: tho### [at] trfde
