POV-Ray : Newsgroups : povray.programming : Calling povray from outside software Server Time
11 Jun 2026 14:33:14 EDT (-0400)
  Calling povray from outside software (Message 1 to 3 of 3)
Subject: Calling povray from outside software
Date: 10 Jan 2003 09:14:45
Message: <3e1ed555$1@news.povray.org>
I am writing a program to help produce animations in povray. I would like to
make it cross-platform (its in Java) but I'm not sure how to go about
calling povray to test the scenes. Povray, however, has different command
line options. For example, if you pass the /EDIT parameter to Povray for
Windows, it will work, even if its already open. However, such an argument
doesn't exist in any other operating systems. What's the recommended way of
calling POV-Ray from an outside program?
Shalom.
PS: I have access to Windows and Linux that I could test my program on (and
I guess DOS, too)
Subject: Re: Calling povray from outside software
Date: 10 Jan 2003 09:46:38
Message: <3E1EDCCE.A2DF0611@gmx.de>
POV-Ray has various command line options that work on all platforms (see
the documentation, section 5).  The windows version has some special
options like /EDIT and /RENDER since it contains an integrated editor.
You obviously should not use them for a platform independant program.
In any case you will have to allow the user to specify the POV-Ray
executable in the program configuration since the name and location will
differ between the platforms.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Jan 2003 14:45:37
Message: <Xns92FF960905EF3tomatimporg@204.213.191.226>
"Shalom Naumann" <sha### [at] fakeemailcom> wrote in
news:3e1ed555$1@news.povray.org:
> like to make it cross-platform (its in Java) but I'm not sure how to
> go about calling povray to test the scenes.
You can take a look at our source code to see how we are tackling it.
http://sourceforge.net/projects/impfarm/
