POV-Ray : Newsgroups : povray.programming : Intensity range of stored radiosity samples Server Time
18 Mar 2026 21:18:39 EDT (-0400)
  Intensity range of stored radiosity samples (Message 1 to 7 of 7)
Subject: Intensity range of stored radiosity samples
Date: 9 Jan 2003 03:46:09
Message: <3e1d36d1$1@news.povray.org>
It appears that the Illuminance RGB values saved by POV-Ray when it
dumps the radiosity data to a file, are only in the [0,1] range. However, if
you had a very bright light source aimed at a wall, surely the illuminance
at points on that wall should be well above 1. In turn, this wall will be
indirectly illuminating other objects and for realism we would really need
to allow values greater than 1, since the wall is now effectively a light
source. Is this not done because of artifacts? Comments?
George Pantazopoulos
Subject: Re: Intensity range of stored radiosity samples
Date: 9 Jan 2003 08:04:58
Message: <3E1D7378.B0556557@gmx.de>
What makes you think this?
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 9 Jan 2003 09:16:53
Message: <3e1d8455$1@news.povray.org>
Looking at an entry of a rad data file, the first chunk contains the
bounce depth, the next three are the point (x,y,z), followed by the packed
surface normal vector. The next three numbers are the Illuminance R,G,B (I
got this info from ot_write_block() in octree.cpp). These numbers have
always been less than 1 in all the rad data I've ever looked at (and I've
ben poring through a lot lately). Also in ra_gather(), Illuminance is of
type COLOUR, which implies a [0,1] range.
George
news:3E1D7378.B0556557@gmx.de...
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 9 Jan 2003 09:29:45
Message: <3E1D8759.E699C928@gmx.de>
No.
Please also check 'max_sample' in the documentation (section 6.11.11.2.8)
which explains how you can indeed artificially limit the range of
illuminance values.
Date: 9 Jan 2003 12:41:27
Message: <cjameshuff-0BC9C0.12314209012003@netplex.aussie.org>
In article <3e1d8455$1@news.povray.org>,
Have you actually bothered to look at the definition for COLOUR?
http://tag.povray.org/
Date: 9 Jan 2003 19:14:10
Message: <3e1e1052$1@news.povray.org>
Christoph and Christopher,
    You are right, COLOUR is made up of floats. I have yet to see a stored
illuminance value above 1 however. I'll try a more definitive test soon.
Thanks for your replies.
George
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 9 Jan 2003 21:37:52
Message: <3e1e3200$1@news.povray.org>
I actually just managed to produce some Illuminance values above 1, using
the Cornell.pov scene. However, I had to up the amibient value of the light
patch from 0.78 to 100.0. The resulting render did not look good, and the
Illuminance values I got were still mostly in the [0,1] range, but there
with some in the 2-3 range, but nothing much higher. So it technically can
be done, but something still does not seem right. I'll have to do more
testing..
Thanks,
George
"George Pantazopoulos" <the### [at] attbicom*KILLSPAM*> wrote in message
news:3e1e1052$1@news.povray.org...
> George
