POV-Ray : Newsgroups : povray.programming : Yet another slight improvement (pattern.cpp - quilt_cubic) Server Time
30 Aug 2025 04:00:21 EDT (-0400)
  Yet another slight improvement (pattern.cpp - quilt_cubic) (Message 1 to 6 of 6)
Subject: Yet another slight improvement (pattern.cpp - quilt_cubic)
Date: 29 Dec 2002 21:26:41
Message: <3e0faee1@news.povray.org>
Came up with it today (Dec. 29). I know it's not a significant improvement,
but at least it shouldn't hurt. With the current implementation, it takes 10
multiplications and 3 additions/subtractions. My version shaves 3
multiplications off the process... not to mention that it eliminates a bunch
of temporaries, which I believe were only there for self-documentation, when
instead you could simply spell it out in the comments.
DBL quilt_cubic(DBL t, DBL p1, DBL p2)
 DBL it = 1.0 - t;
 return (t * (t*t + 3.0*it*(it*p1 + t*p2) ) * INV_SQRT_3_4);
Anthony Bennett
Subject: Re: Yet another slight improvement (pattern.cpp - quilt_cubic)
Date: 29 Dec 2002 22:19:47
Message: <chrishuff-BD1200.22152229122002@netplex.aussie.org>
In article <3e0faee1@news.povray.org>, "Tony[B]" <ben### [at] catholicorg>
A lot of the patterns are like that...I think they were there to help
old compilers optimize somehow. They don't make much sense otherwise, my
favorite example:
static DBL onion_pattern (VECTOR EPoint)
  /* The variable noise is not used as noise in this function */
  register DBL noise;
Writing a 50-some character comment instead of changing a 5 character
variable name...I hope there was a really good reason to use the name
"noise".
Some others are to prevent duplicated calculations when passed to macros
like Sqr().
There are also inconsistencies and inefficiencies in the range
clipping...the pattern code could be greatly improved.
While you are at it, the wood pattern takes the 3D length of a vector
where 2D would suffice...you could save a multiplication and addition.
There are "bigger fish to fry" though...making these patterns as fast as
possible will only speed POV a little. An algorithm improvement
elsewhere (like transparency calculation) could accomplish much more.
http://tag.povray.org/
Date: 29 Dec 2002 22:35:07
Message: <3e0fbeeb@news.povray.org>
I know what you mean. And then there are comments such as this one:
  /* This form didn't work with Zortech 386 compiler */
  /* value = Sqr((sin(x)+sin(y)+sin(z))/3); */
  /* So we break it down. */
I think we can move past this now... right?
I hope to slowly work my way through it and find more to fix.
Yes, that's true, I admit it. The sad part is that since I have trouble
comprehending other parts of the code, this is about as big a contribution
as I can make. :(
Anthony Bennett
Date: 30 Dec 2002 06:25:56
Message: <3e102d44@news.povray.org>
Noooo!
Don't you dare render my Zortech 386 obsolete!
PGP Public Key
Version: 6.0.434 / Virus Database: 243 - Release Date: 25/12/2002
Date: 30 Dec 2002 08:08:53
Message: <3e104565@news.povray.org>
  On the other hand, if someone has the free time and is willing to do it,
then why not?
  A 0.1% speed improvement is better than a 0% speed improvement. :)
  (Of course we have to remember that if these things are going to be in
the official POV-Ray, they will have to be carefully studies by a pov-team
member, who might not have that much time and willingness.)
Date: 30 Dec 2002 10:47:52
Message: <3e106aa8@news.povray.org>
> then why not?
Hear-hear! :)
I have a simple solution to that: make me a POV-Team member. ^_^
Anthony Bennett
