POV-Ray : Newsgroups : povray.programming : GuiExt on Linux? Server Time
11 Jul 2026 13:58:48 EDT (-0400)
  GuiExt on Linux? (Message 1 to 8 of 8)
Subject: GuiExt on Linux?
Date: 14 Dec 2002 22:25:27
Message: <3dfbf627$1@news.povray.org>
Is there a similar mechanism on Linux/Unix POV to the GUI Extensions on
POV-Ray for Windows.  Now obviously I know the Linux version is run from the
command-line.  My specific question is, is there a way to get the pixels
from Linux POV as the render is happening, instead of waiting until the
render is complete?
Andrew Wilcox
Subject: Re: GuiExt on Linux?
Date: 14 Dec 2002 22:52:23
Message: <1626040.Y8fERm4Gub@3-e.net>
> the
> render is complete?
Have you looked at these?
http://pyvon.sourceforge.net/UK_index.html
http://www.azweb.de/kpovmodeler/
Your connection failed because: parallel processors running perpendicular
today
Date: 15 Dec 2002 00:34:05
Message: <3dfc144d$1@news.povray.org>
Ok, so there are GUI tools for POV.  But, is there a way to hook into an
actual POV process on Linux and get the pixels as they are rendered, instead
of waiting for the final output image?
Andrew Wilcox
Date: 15 Dec 2002 04:19:35
Message: <1173597.anYzTcuZfo@3-e.net>
Other than x-povray? What exactly are you wishing to do that the code of
pyvon etc. can't show how to you?
> instead of waiting for the final output image?
> Andrew Wilcox
Your connection failed because: Dew on the telephone lines.
Date: 15 Dec 2002 12:58:45
Message: <3dfcc2d5$1@news.povray.org>
I'm not actually trying to implement it right now.  I don't actually have a
Linux/Unix box to work on.  As part of the program I'm writing, I'm building
a generic api to spawn POV renders, and I was just wanting to know if it's
possible on Linux to capture the pixel stream as it is being rendered.  I
think I was just hoping for a simple yes or no answer. :-)
Thanks,
Andrew Wilcox
Date: 15 Dec 2002 14:45:19
Message: <3dfcdbcf$1@news.povray.org>
In article <3dfcc2d5$1@news.povray.org> , "Andrew Wilcox"
Yes.  Redirect the image output stream to your application.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 15 Dec 2002 16:50:17
Message: <3dfcf919$1@news.povray.org>
Thanks, that's what I needed to know.
>     Thorsten
Date: 16 Dec 2002 06:08:56
Message: <3dfdb448@news.povray.org>
> render is complete?
  If you are using the Linux binaries and running it under X, then the
command-line option "+d" should open a preview window while rendering.
  You can put that option (and other you always use) in the ~/.povrayrc
file so that you don't have to write it every time you render something.
