POV-Ray : Newsgroups : povray.programming : Which codes are about the process of the translation Server Time
11 Nov 2025 13:52:58 EST (-0500)
  Which codes are about the process of the translation (Message 1 to 2 of 2)
Subject: Which codes are about the process of the translation
Date: 12 Dec 2002 22:32:11
Message: <3df954bb@news.povray.org>
Hi, all
  I am now trying to track a moving object. I set clock in translate to make
the object move. For example, add  translate <-7*clock*clock,0,-clock> into
an object description. I want to know which codes are about the process of
the translation. Thanks
Wu Yang
Subject: Re: Which codes are about the process of the translation
Date: 13 Dec 2002 08:52:34
Message: <3df9e622$1@news.povray.org>
In article <3df954bb@news.povray.org> , "Wu Yang" <wya### [at] cswrightedu>
For all objects but those which are trivial to translate POV-Ray implements
the translation as part of the transformation matrix.  The code for matrices
can be found in matrices.cpp.  The transformation is part of an object can
can be found in the "Trans" member, which is a pointer to a "TRANSFORM".
    Thorsten
e-mail: tho### [at] trfde
