POV-Ray : Newsgroups : povray.programming : POV-Ray parser in Java Server Time
16 Dec 2025 20:22:40 EST (-0500)
  POV-Ray parser in Java (Message 1 to 10 of 28)
Subject: POV-Ray parser in Java
Date: 4 Dec 2002 16:06:52
Message: <3dee6e6c$1@news.povray.org>
Would anyone else find this useful?  I started writing it, and I'm past the
hardest part, and am left with just the tedious task of finding all the
keywords defined in POV, and implementing the symantic control of which
keywords are allowed in which objects.
For the most part what I need works, but can anyone give me a good reason to
go ahead and complete this 100%?
Andrew Wilcox
Subject: Re: POV-Ray parser in Java
Date: 4 Dec 2002 16:25:37
Message: <3dee72d1$1@news.povray.org>
In article <3dee6e6c$1@news.povray.org> , "Andrew Wilcox"
Macros?
    Thorsten
Date: 4 Dec 2002 16:33:00
Message: <3dee748c$1@news.povray.org>
Actually, just parsing expressions is what I consider the hardest part.
Right now, it lexes, tokenizes, and starts objectizing the stream.  It
doesn't actually evaluate directives yet, but this is really just symbol
table manipulation which for the most part isn't too hard.
> Macros?
>     Thorsten
Date: 4 Dec 2002 16:35:09
Message: <3DEE750B.3B747C9B@gmx.de>
> Macros?
Functions? ;-)
For a POV-Ray 3.5 compatible parser you really would need to duplicate
half of POV-Ray to successfully parse a POV-Ray scene, even if you leave
out textures.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 4 Dec 2002 16:42:57
Message: <3dee76e1@news.povray.org>
Maybe I should reclarify.  I don't think actually fully parsing the scene is
feasible anytime soon, especially with functions, but building a parse tree
is.  Which would allow for manipulation of the scene language itself.  This
could then be rewritten and let POV actually do the full parse to generate
the scene.  I can't think of a good reason for actually evaluating the
scene.
AW
news:3DEE750B.3B747C9B@gmx.de...
> > Macros?
> Functions? ;-)
> out textures.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 7 Jan 2003 11:56:24
Message: <3e1b06b8$1@news.povray.org>
Most definitely, no -- if by "useful" you mean something that could be used
for any real-world applications and not just in a students' toy project,
thesis, and the likes.
What (I think) would be indeed highly useful are lex/flex and bison/yacc
conunterparts with licenses more open than GPL. In fact, a good FSM-based
parser is what POV-Ray is currently missing badly, IMHO.
Date: 7 Jan 2003 13:15:13
Message: <3e1b1931$1@news.povray.org>
Could be very interesting for a remote-POV-Ray computing website. You have a
heavy box running POV-Ray on the webserver with https (ssl) and you can
render stuff from anywhere you are, just using a web-browser with Java
enabled or a java application with sockets. The rendered output comes back
to where you are or is being mailed to an e-mail address. Maybe some thing
like global settings {mailto bil### [at] microsoftcom} would be funny
enhancement for the remote povray thing ?  :-)
Date: 7 Jan 2003 18:06:57
Message: <BA410C8C.8D7C%fidel.viegas@artrecognition.co.uk>
in article 3dee76e1@news.povray.org, Andrew Wilcox at awi### [at] unpuzzledcom
wrote on 4/12/02 9:43 pm:
> scene.
> AW
Hi Andrew, are you writing the parser by hand? If yes, then you should have
a look at either JFlex and CUP (java equivalent to flex and bison), SableCC
(which generates the parse tree for you) or ANTLR (which allow you to define
tree walkers as well as parsers and scanners). SableCC you can download it
from www.sablecc.org. ANTLR you can download it from www.antlr.org, JFlex
you can download it from www.jflex.de and CUP you can download it from
http://www.cs.princeton.edu/~appel/modern/java/CUP/.
Try SableCC as it is very easy to use.
All the best
Fidel.
Date: 8 Jan 2003 10:55:30
Message: <3e1c49f2$1@news.povray.org>
Well, I've thought of a couple of potential uses.  My overall goal is trying
to build a render farm program, and there are some tricky points.  One of
the things I am trying to do is determine all the resource files needed by a
POV-Ray scene file.  Things like #include files, and image files for
mappings and such.  To some degree even resources where the name is
generated at parse time could be figured out, unless some super complicated
method is used (like using a function or something).  Also, if done right
you could add syntax which could be parsed and rewritten in standard POV
SDL.  For example adding a #for statement, that gets rewritten as a #while.
It wouldn't be something most people would want to do, but it might make my
life easier sometimes. :-)
AW
Date: 8 Jan 2003 16:45:38
Message: <3e1c9c02@news.povray.org>
In article <3e1b06b8$1@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
No, that isn't correct.  You should not make such bold claims without
profiling the code first!  And this issue has been discussed often in the
past.
    Thorsten
e-mail: tho### [at] trfde
