POV-Ray : Newsgroups : povray.programming : gradient Server Time
30 Aug 2025 04:00:21 EDT (-0400)
  gradient (Message 1 to 4 of 4)
Subject: gradient
Date: 2 Dec 2002 11:45:46
Message: <3deb8e39@news.povray.org>
Hello,
if I remember correctly, I came across some code in povray or one of its
patches that calculates the gradient of a pattern or function. By this
I mean a function that numerically finds the direction of a real valued
function f at some point p in space in which f increases most. This was
done by evaluating the function slightly off p. To improve numerical
stability, the code in question used the four vertices of a tetrahedron
and evaluated the function f there. So, if v1,...,v4 denote the vertices
of a tetrahedron centered at the origin, the function f was evaluated at
p+v1, p+v2, p+v3 and p+v4.
Unfortunately I cannot find this code anymore. Does somebody know what
I'm writing about and the file to look at?
Thanks in advance.
Subject: Re: gradient
Date: 2 Dec 2002 12:02:55
Message: <3DEB923F.58AEAF86@gmx.de>
Thomas Willhalm wrote:
> Hello,
You have some POV-SDL based macros for gradient calculation in
'math.inc'.  Apart from that the isosurface normal calculation code does
something similar too, function 'IsoSurface_Normal()' in 'isosurf.cpp'.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 3 Dec 2002 02:57:34
Message: <3dec63ed@news.povray.org>
>> Hello,
Thanks, this function does what I want, although it's not the function
I vaguely remember. Perhaps it was in a different program, but I have
no clue what program this should be.
Thanks again
Date: 3 Dec 2002 06:29:18
Message: <ra5puuse9or3trqbfj8pv2dvantu8d4t4s@4ax.com>
On Tue, 03 Dec 2002 08:57:21 +0100, Thomas Willhalm
I think the julia_fractal and blob objects use similar approaches to
calculating the normal (aside from the isosurface code Christoph
mentioned).
Peter Popov ICQ : 15002700
