POV-Ray : Newsgroups : povray.programming : Apply gamma correction after antialiasing Server Time
30 Aug 2025 04:02:32 EDT (-0400)
  Apply gamma correction after antialiasing (Message 1 to 10 of 10)
Subject: Apply gamma correction after antialiasing
Date: 27 Nov 2002 13:43:57
Message: <3de5126d$1@news.povray.org>
POV-Ray currently applies gamma correction before antialiasing, while it
should be applied after antialiasing, since averaging of colors must be done
in a linear color space. For a sample picture that make this problem very
obvious, see the thread "Anti-Aliasing Problem including sample image (58k)"
in povray.binaries.images.
Here's a patch:
--- povwin-3.5-orig/source/render.cpp Sun Jul 28 00:55:32 2002
+++ povwin-3.5/source/render.cpp Wed Nov 27 13:31:48 2002
@@ -1571,6 +1571,7 @@ void Start_Adaptive_Tracing()
       POV_PRE_PIXEL (x, Current_Line_Number, Colour)
       trace_sub_pixel(1, Block, x, Current_Line_Number, 0, 0,
sub_pixel_size, sub_pixel_size, sub_pixel_size, Colour, antialias_line);
+      gamma_correct(Colour);
       POV_POST_PIXEL (x, Current_Line_Number, Colour)
       /* Do histogram stuff. */
@@ -2084,7 +2085,6 @@ static void supersample(COLOUR result, i
         Clip_Colour(colour, colour);
-        gamma_correct(colour);
         Add_Colour(result, result, colour);
       else
@@ -2100,6 +2100,7 @@ static void supersample(COLOUR result, i
   /* Average pixel's color. */
   Scale_Colour(result,result,(1.0/samples));
+  gamma_correct(result);
@@ -2330,8 +2331,6 @@ static void trace_ray_with_offset(int x,
       Clip_Colour(Colour, Colour);
-      gamma_correct(Colour);
     else
light_source{6#local D=#macro B(E)#macro A(D)#declare E=(E-#declare
C=mod(E D);C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(
C>2)}torus{1..2clipped_by{box{-2y}}rotate<1 0C>*90translate<D+1A(2)
*2+1#else}cylinder{0(C-v=1).2translate<D+C*A(2)A(4)#end-2 13>finish
{specular 1}pigment{rgb x}#end#end#end-8;1B(445000298)B(519053970)B
(483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Subject: Re: Apply gamma correction after antialiasing
Date: 27 Nov 2002 15:48:35
Message: <3DE52F9F.EC60356F@gmx.de>
Just for the record: although such a change is surely a good idea this
does not mean the linear interpolation of colors in rgb space is the
optimal solution for color blending problems.  Despite such a change
unwanted colors may still occur.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 27 Nov 2002 16:38:52
Message: <3de53b6c@news.povray.org>
In article <3de5126d$1@news.povray.org> , "Anders K." <and### [at] kaseorgcom>
We know.  It has been fixed some time ago and will be made available in
POV-Ray 3.51 in the future.
    Thorsten
PS: Before anybody asks, I am not going to provide any details when it will
be released.  It surely won't be tomorrow, so don't hold your breath! ;-)
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 27 Nov 2002 16:39:39
Message: <3de53b9b$1@news.povray.org>
wrote:
> Here's a patch:
Hint:  There is a bit more to this, but it is a long story...
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Nov 2002 16:50:04
Message: <web.3de53dcd6040bc4978071460@news.povray.org>
Hmm probably a stupid question, but I must know: will it include the
sphere_sweep speed optimisation I read about some time ago (together with
the bugfix of course)? Such a cool primitive, it's a shame it renders that
slow.
Jonathan
Date: 27 Nov 2002 16:57:34
Message: <3de53fce$1@news.povray.org>
I'm not sure I see why. I've never seen unwanted colors testing my patch,
even when I deliberately lined up two clashing colors halfway between pixel
boundries:
// +w160 +h120 +am1 +r8 +a0.0
global_settings { assumed_gamma 1.0 }
camera { orthographic right 4/3*x up y direction z }
plane { -z, -1 pigment { checker rgb <0, 1, 1>, rgb <1, 0, 1> scale 1/4
translate 1/240 } finish { ambient 1 } }
But I'm curious to hear what you have in mind.
Anders
Date: 27 Nov 2002 17:15:40
Message: <3de5440c@news.povray.org>
In article <3de53fce$1@news.povray.org> , "Anders K." <and### [at] kaseorgcom>
Christoph's argument is valid, and one would indeed expect problems either
way.  Tests showed that they don't exist, even with Clip_Colour being
performed after averaging you get good antialiasing and not even visible
color blending problems!  Don't ask me why, I don't know because I have not
investigated it in detail as the result is good...
    Thorsten
Date: 27 Nov 2002 17:18:37
Message: <3de544bd$1@news.povray.org>
In article <web.3de53dcd6040bc4978071460@news.povray.org> , "JRG"
> slow.
It will contain all suitable bug fixes the POV-Team knows about.  You can
assume we know about every bug fix that has been discussed here or is
mentioned on ABX's site.  Apart from that, please don't ask about details.
    Thorsten
Date: 27 Nov 2002 17:40:34
Message: <3DE549E2.EB5201C0@gmx.de>
> boundries:
See the thread in p.b.i. for some arguments in that concern.
Interpolating between two strongly different colors with convincing
results is a difficult task.  One method would be to always interpolate
via some gray (or near to gray) value, this of course only makes sense if
the difference between the two colors is fairly large.
Date: 28 Nov 2002 02:11:48
Message: <d7gbuu4kr5enjdvaclhpiqvnma1b721sqo@4ax.com>
> slow.
That speedup will be rather in something like MegaPOV or PoPOV first.
It's currently under testing so will be released soon probably.
ABX
