POV-Ray : Newsgroups : povray.programming : Can I set more rays in one pixel? Server Time
29 Sep 2024 04:19:04 EDT (-0400)
  Can I set more rays in one pixel? (Message 1 to 5 of 5)
Subject: Can I set more rays in one pixel?
Date: 23 Nov 2002 06:13:12
Message: <3ddf62c8$1@news.povray.org>
Hi, all
   I want more details about the object in the scene, so I need more
intersection points. Can I set more rays in one pixel? Thanks
Best Regards
Wu Yang
Subject: Re: Can I set more rays in one pixel?
Date: 23 Nov 2002 07:03:05
Message: <3ddf6e79$1@news.povray.org>
In article <3ddf62c8$1@news.povray.org> , "Wu Yang" <wya### [at] cswrightedu>
wrote:
> Hi, all
Read the documentation about antialiasing.
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Nov 2002 21:36:49
Message: <chrishuff-585F8D.21351723112002@netplex.aussie.org>
In article <3ddf62c8$1@news.povray.org>,
Extremely simple: render at a higher resolution. Won't require any
changes to the patch. More pixels, more rays per pixel, same effect of
more rays.
It is really sounding more and more like a patch just isn't the right
solution though...nothing you've described can't be done with plain
scene description language.
As someone mentioned, antialiasing takes multiple samples per pixel, but
I don't think this is what you want...since I don't really know what
you're doing, I can't really tell. It will probably take at least some
modifications to the patch.
http://tag.povray.org/
Date: 25 Nov 2002 03:29:24
Message: <3de1df64$1@news.povray.org>
Thank you for your reply.
>I don't really know what you're doing, I can't really tell. It will
probably take at least some modifications to the >patch.
Now I need set the camera far from the object, so the object is very small.
But I still want to get enough intersection points. Can I set the resolution
as high as I want and what modifications do I need? Thanks.
Best Rrgards
Wu Yang
Date: 25 Nov 2002 04:50:06
Message: <3DE1F268.8060405@free.fr>
Distance of camera to object may be irrelevant with an orthographic
camera. The angle of the camera might rather interfer too.
(telephoto lens have a very small angle).
But if your object is only 10x10 pixels on the final renders, you won't
be able to see much details. Using Antialiasing will just shoot more
rays at it and performs some integration, but at the end a pixel can
only have one colour.
Increasing the image size would be better for the details (especially if
you keep antialiasing too!).
You can set the image size as big as you want (reasonnably for your
computer anyway) and there is no need for any modification.
See the +H and +W switches in the pov-help.
Image resolution of 10000 x 10000 have been done with Povray.
You just need the disc space to store it...
