POV-Ray : Newsgroups : povray.programming : (Request) Re: Height field bug found and fixed Server Time
11 Jun 2026 15:43:40 EDT (-0400)
  (Request) Re: Height field bug found and fixed (Message 1 to 9 of 9)
Subject: (Request) Re: Height field bug found and fixed
Date: 6 Nov 2002 05:22:40
Message: <3dc8ed70@news.povray.org>
In article <3da337e1$1@news.povray.org> , "Slime" <slm### [at] slimelandcom> wrote:
> Have you ever created a smooth height field with some flat areas? Noticed
> how the smoothing around the flat areas, although looking rounded, doesn't
> quite look entirely *smooth*? See the image in p.b.i.
<snip>
I noticed that you made your patch available, but it also includes numerous
extensions to the code that have nothing to do with the actual problem.
Would it be possible to provide a hfield.cpp which only fixes the bug and
not requiring me to carefully dissect the code and remove everything that is
not part of the bug fix?
This would really speed-up the process of integrating your bugfix into a
future official POV-Ray 3.5 :-)
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: (Request) Re: Height field bug found and fixed
Date: 6 Nov 2002 05:29:04
Message: <9frhsusgnd00nurrsom1gg4dmoaec132eu@4ax.com>
On Wed, 06 Nov 2002 11:22:40 +0100, "Thorsten Froehlich" <tho### [at] trfde>
I'm not sure we are talking about the same bugfix but I have received changes
extracted by Slime and you can find it in PoPOV marked with SMOOTH_HF_PATCH
ABX
Date: 6 Nov 2002 06:06:45
Message: <3dc8f7c5$1@news.povray.org>
In article <9frhsusgnd00nurrsom1gg4dmoaec132eu@4ax.com> , ABX
Well, that is the code I am refering to.  It contains numerous extension as
well, which is the problem.
    Thorsten
Date: 6 Nov 2002 06:20:48
Message: <3DC8FB0C.7FA0E868@gmx.de>
But note that 'hfield.cpp' from slimepov and popov are not identical, the
'SMOOTH_HF_PATCH' from popov is really only a small modification (in line
880 and 890 in the file from popov) so it's easy to extract.
Last updated 02 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 6 Nov 2002 06:24:34
Message: <rpuhsuc9vuk5gbcntqrld044e1qdv2oiab@4ax.com>
On Wed, 06 Nov 2002 12:20:44 +0100, Christoph Hormann <chr### [at] gmxde>
from PoPOV ;-)
ABX
Date: 6 Nov 2002 07:01:22
Message: <3dc90492@news.povray.org>
In article <3dc8f7c5$1@news.povray.org> , "Thorsten Froehlich"
Actually, the code I was refering to was that now inside
NORMAL_ACCURACY_BUGFIX_PATCH.
Thanks for the link in the email.  I now have what I was looking for.
    Thorsten
Date: 6 Nov 2002 13:43:42
Message: <3dc962de$1@news.povray.org>
numerous
is
Mmm. I haven't touched the patch for a while. I'll see if I can create a new
hfield.cpp.
All you want is the smoothing artifact bugfix, right? (Not to be confused
with the normal accuracy bugfix, which has nothing to do with height fields,
but should probably also be included in the official version. That's just a
single line change though.)
I'll email it to you later.
 - Slime
[ http://www.slimeland.com/ ]
Date: 6 Nov 2002 13:51:32
Message: <gooisuo1urvhjjj4nqqvlfjudafvufmi8r@4ax.com>
Slime, please, look at hfield.cpp in PoPOV. Somehow I feel all changes I have
introduced are correct but perhaps marked wrong. Thanks in advance.
ABX
Date: 7 Nov 2002 00:16:59
Message: <3dc9f74b$1@news.povray.org>
have
I'll do that as soon as I get around to Thorsten's request, also.
I apologize in advance that it will take me a little time to get back to
both of you since I have a paper due soon that I need to work on. However,
if I forget for a significant period of time, feel free to email me with a
reminder. I'll try not to forget though =)
 - Slime
