POV-Ray : Newsgroups : povray.programming : Several blob bugs (job000189) [2] Server Time
2 Apr 2026 05:28:12 EDT (-0400)
  Several blob bugs (job000189) [2] (Message 1 to 4 of 4)
Subject: Several blob bugs (job000189) [2]
Date: 2 Nov 2002 04:12:38
Message: <3dc39706@news.povray.org>
The following patch fixes some bugs reported at
http://www.povray.org/download/3.5-bugs.php.
In particular it should fix:
http://news.povray.org/3b99052c@news.povray.org (at least the 2nd)
http://news.povray.org/Xns9115B92CF7D8ACQ@204.213.191.226
http://news.povray.org/Xns91203DC7F3CCQ@204.213.191.226
http://news.povray.org/3be5f0b2@news.povray.org
A simple explanation (without formulas) is:
All bug reports concern with big/small blob objects.
Let's represent an object using millimeters as pov unit, we'll
have a direction of 1 mm, and the depth of the intersections will be
in mm. But if you represent the same object in meters, the ray direction
is 1 m long, and the depth of the intersections are now in m. The problem
is that the equations representing these intersections are fourth order
polinomials and it is easy to exceed limits and lose accuracy.
So, when computing the equations I scale ray's direction proportionally
to a dimension of the object, and then the computed depths
are scaled back to the original unit.
The patch is against blob.cpp (as it is in povray-3.50a for linux).
If it is not worth to be included in the vanilla-povray (it needs
extensive tests), I hope it's a good starting point for those interested
in fix these bugs.
Comments are welcome.
HTH Massimo
--- src/blob.cpp.ex Sat Nov  2 09:30:34 2002
+++ src/blob.cpp Sat Nov  2 09:30:34 2002
@@ -344,8 +344,11 @@
     start_dist = 0.0;
+  DBL Max_Bound = intervals[0].bound;
   for (i = 0; i < cnt; i++)
+    if (intervals[i].bound > Max_Bound)
+      Max_Bound = intervals[i].bound;
     intervals[i].bound -= start_dist;
@@ -353,6 +356,20 @@
   VAddScaledEq(P, start_dist, D);
+  if (Max_Bound != 0)
+    VScaleEq(D, Max_Bound);
+    for (i = 0; i < cnt; i++)
+      intervals[i].bound /= Max_Bound;
+  else
+    Max_Bound = 1;
   /* Clear out the coefficients. */
   coeffs[0] =
@@ -389,6 +406,7 @@
           VDot(t0, V1, V1);
           VDot(t1, V1, D);
+          t2 = Max_Bound * Max_Bound;
           c0 = Element->c[0];
           c1 = Element->c[1];
@@ -396,9 +414,9 @@
           fcoeffs = &(Element->f[0]);
-          fcoeffs[0] = c0;
-          fcoeffs[1] = 4.0 * c0 * t1;
-          fcoeffs[2] = 2.0 * c0 * (2.0 * t1 * t1 + t0) + c1;
+          fcoeffs[0] = c0 * t2 * t2;
+          fcoeffs[1] = 4.0 * c0 * t1 * t2;
+          fcoeffs[2] = 2.0 * c0 * (2.0 * t1 * t1 + t0 * t2) + c1 * t2;
           fcoeffs[3] = 2.0 * t1 * (2.0 * c0 * t0 + c1);
           fcoeffs[4] = t0 * (c0 * t0 + c1) + c2;
@@ -584,7 +602,7 @@
         /* Correct distance. */
-        dist = (dist + start_dist) / len;
+        dist = (dist * Max_Bound + start_dist) / len;
         if ((dist > DEPTH_TOLERANCE) && (dist < Max_Distance))
Subject: Re: Several blob bugs (job000189) [2]
Date: 2 Nov 2002 08:33:07
Message: <3DC3D413.F95086FB@gmx.de>
> in fix these bugs.
I think in general it would be better to post modified versions of the
original files with marked changes than a diff.  It's always possible that
people who want to use your modifications don't have exactly the same file
as you and have problems applying the changes.
Last updated 28 Oct. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Nov 2002 12:09:40
Message: <3DC406D3.3EED8E86@attglobal.net>
Massimo,
Thank you very much for your work on these bugs! I am regularly
picking up and applying your patches to my personal version of
POV-ray 3.5!
Regards, Bill P.
Date: 2 Nov 2002 13:10:14
Message: <3dc41506@news.povray.org>
"Christoph Hormann" ha scritto
: I think in general it would be better to post modified versions of the
: original files with marked changes than a diff.  It's always possible that
: people who want to use your modifications don't have exactly the same file
: as you and have problems applying the changes.
Well, I dont want anybody to apply the diff against a custom blob.cpp
I thought that it is possible to extract from the source tar(zip), a copy
of the original blob.cpp and apply the patch against it. This way the diff
already marks clearly the changes, IMHO better than in a 70Kb cpp file.
Anyway I posted the whole file to povray.binaries.programming.
Massimo
