POV-Ray : Newsgroups : povray.programming : About the Mesh Server Time
29 Sep 2024 04:18:44 EDT (-0400)
  About the Mesh (Message 1 to 9 of 9)
Subject: About the Mesh
Date: 23 Oct 2002 23:49:12
Message: <3db76db8@news.povray.org>
Hi, all
    In mesh.cpp, there is a Intersect_Mesh() function. In this function,
there is a Mesh pointer and I found that  Mesh->Data->Vertices is the x
values of a triangle corners. Is that right? How can I get the x, y, z
values of the corners?
Thanks
Wu Yang
Subject: Re: About the Mesh
Date: 24 Oct 2002 04:48:09
Message: <3db7b3c9@news.povray.org>
In article <3db76db8@news.povray.org> , "Wu Yang" <wya### [at] cswrightedu>
No offense, but given the kind of questions you ask you may want to learn a
bit more C first and maybe gain experience with less complex applications
before you start looking into the POV-Ray source code.
As you should be able to see easily from the source code, Mesh->Data is
pointer to Mesh_Data_Struct and Vertices is an array of SNGL_VECT...
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Oct 2002 08:52:47
Message: <3db7ed1f@news.povray.org>
Thank you for your reply. What I mean is that: when I see the value of
Mesh->Data->Vertices, I can get three values. These three values is the x
values of a triangle's three corners, not (x,y,z) of a corner. I want get
the (x,y,z) of every corner. Could you please give me some advice? Thanks
Wu Yang
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3db7b3c9@news.povray.org...
a
>     Thorsten
Date: 24 Oct 2002 10:14:19
Message: <3DB80055.6050701@free.fr>
> Wu Yang
No offense again, but you do not understand the Mesh data structure.
The three values of a line of the Mesh->Data->Vertices are the (x,y,z)
of a single Vertex.
I believe you are not yet ready to play with the mesh code!
Date: 24 Oct 2002 10:31:17
Message: <chrishuff-BA6C20.10243124102002@netplex.aussie.org>
In article <3db7ed1f@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
No, it isn't. It's what he said it was, and what the code says it is: a
SNGL_VECT, a single-precision vector.
> I want get the (x,y,z) of every corner. Could you please give me some
> advice? Thanks
I'd have to agree with the advice he has already given: learn C. Your
questions indicate that you don't know it, and messing around with
anything but the most basic things without knowing the language POV is
written in is just not going to work.
Ideally, get a simple primer book on C++, POV was originally written in
C, so most of it is structured like a C program, but it now uses C++. I
have a book called the "C++ Primer Plus" by the Waite group that I'd
recommend.
Once you've got the basics down, then you have a chance of understanding
the POV code...but don't expect to have everything handed to you on a
silver platter, you will have to carefully read the code and look at the
structure of the different parts. And when someone tells you something
or asks you a question, don't just ignore what they said.
http://tag.povray.org/
Date: 24 Oct 2002 10:31:24
Message: <3db8043c$1@news.povray.org>
In article <3db7ed1f@news.povray.org> , "Wu Yang" <wya### [at] cswrightedu>
No, a vertex is a "corner".  And "vertices" is the plural of "vertex".
> I want get
You need to know the index of the three triangle vertices, as the whole
mesh.cpp code does all over the place:
MESH *Mesh = ...;
MESH_TRIANGLE *Triangle = &(Mesh->Triangles[index]);
Mesh->Data->Vertices[Triangle->P1][X]
Mesh->Data->Vertices[Triangle->P1][Y]
Mesh->Data->Vertices[Triangle->P1][Z]
Mesh->Data->Vertices[Triangle->P2][X]
Mesh->Data->Vertices[Triangle->P2][Y]
Mesh->Data->Vertices[Triangle->P2][Z]
Mesh->Data->Vertices[Triangle->P3][X]
Mesh->Data->Vertices[Triangle->P3][Y]
Mesh->Data->Vertices[Triangle->P3][Z]
Really, I don't want to be discouraging, but if you have such problems, it
will be a very frustrating experience to look at the POV-Ray source code.
And you won't be learning much from it...
    Thorsten
Date: 24 Oct 2002 10:32:12
Message: <3db8046c@news.povray.org>
Thank you for your reply. But the following is what I did.
In *.pov file
     mesh {
   smooth_triangle { <-18.2369, 57.4258, 115.298>,
<-0.333333, -0.666667, -0.666667>, <-32.0698, 57.4258, 99.813>,
<0.449391, -0.887923, 0.098189>, <-32.0698, 57.4258, 115.298>,
<0.816497, -0.408248, -0.408248> }
And the Mesh->Data->Vertices I saw is<-18.2369, -32.0698, -32.0698>. Is this
the (x,y,z) of a single Vertex?Thank you.
Wu Yang
"Le Forgeron" <jgr### [at] freefr> wrote in message
news:3DB### [at] freefr...
x
get
Thanks
> > Wu Yang
> of a single Vertex.
Date: 24 Oct 2002 10:49:33
Message: <3db8087d@news.povray.org>
I got it. Thank you very much.
Best Regard
Wu Yang
news:3db8043c$1@news.povray.org...
x
> > I want get
Thanks
> MESH *Mesh = ...;
>     Thorsten
Date: 24 Oct 2002 10:58:53
Message: <3db80aad@news.povray.org>
In article <3db8046c@news.povray.org> , "Wu Yang" <wya### [at] cswrightedu>
Well, if you see that you don't understand what the debugger is showing you.
Not knowing which IDE you are using, I am going to guess it is Visual
Studio:  You should be able to expand (the little box with the plus sign)
each of those rows to see all entries.
    Thorsten
