POV-Ray : Newsgroups : povray.programming : Changes to Option_Variable[] Server Time
29 Sep 2024 04:22:24 EDT (-0400)
  Changes to Option_Variable[] (Message 1 to 1 of 1)
Subject: Changes to Option_Variable[]
Date: 22 Oct 2002 08:15:09
Message: <3db54147@news.povray.org>
Hi there.
I have just started working on porting the PVM patch for POVRay from 3.1g to
3.5 and noticed a fairly large change in the way Option_Variable[] works.
There doesn't appear to be much documentation about it.  I hope that someone
could point me in the right direction.
The old code uses:
  { PVM_TASKS_OP, "PVM_Tasks" },
  { PVM_WIDTH_OP, "PVM_Width" },
  { PVM_HEIGHT_OP, "PVM_Height" },
  { PVM_SLAVE_OP, "PVM_Slave" },
and sets the variables in void process_variable(TOKEN variable,char *value)
as shown below:
   case PVM_TASKS_OP:
       if (sscanf(value, "%d", &PvmTasks) != 1 || PvmTasks < 1) {
          PvmTasks = 9999;   /* Try to start one slave/available PVM host */
       return;
   case PVM_WIDTH_OP:
       if (sscanf(value, "%d", &PvmChunkWidth) != 1 || PvmChunkWidth < 4)
          PvmChunkWidth = PVM_DEFAULT_GRID_WIDTH;
       return;
   case PVM_HEIGHT_OP:
       if (sscanf(value, "%d", &PvmChunkHeight) != 1 || PvmChunkHeight < 4)
          PvmChunkHeight = PVM_DEFAULT_GRID_HEIGHT;
       return;
   case PVM_SLAVE_OP:
       PvmSlavename = POV_MALLOC( sizeof(char)*(strlen(value)+1),
                                 "PVM Slavename");
       strcpy(PvmSlavename, value);
       return;
What is the new way of preforming this?  Is this likely to change again in
future versions?
I think I see how Command_Option[] works, or at least how it relates to the
new Option_Variable[] works.
Thanks for any assistance.
Lee Begg
