POV-Ray : Newsgroups : povray.programming : How does parser.cpp/parstxtr.cpp work? Server Time
2 Apr 2026 05:27:33 EDT (-0400)
  How does parser.cpp/parstxtr.cpp work? (Message 1 to 6 of 6)
Subject: How does parser.cpp/parstxtr.cpp work?
Date: 21 Oct 2002 13:26:36
Message: <3db438cb@news.povray.org>
Can someone please explain to me, or point me to a direction/documentation,
how the parser works?
Its quite hard for an C novice to understand the inner working of the parser
with all these marcros and definitions...
Or simply help me with my current prob?
My trouble is as follows:
I started to create a grid-pattern. This was created as a block-pattern
in that way, that I simply copied everywhere (where I found it) the brick-
pattern and renamed it.
At last I changed the inner working in pattern.cpp so I had what I wanted.
Fine! This worked, and I was happy.
But I decided, I could create a more useful pattern, if I would return a
float and later apply a colormap instead of a simple color.
Returning the float works ok, so far, but as this started as a copy of a
brick-pattern, I can't apply a colormap. I assume the appropriate code lies
in the parser. Can someone tell me, where which token has how to be added?
Thx ... Jan ...
PS: Question from newbie:
	struct *T;
	T->A.B == (*T).A.B ?
    I'm still getting confused with pointerstuff....
Subject: Re: How does parser.cpp/parstxtr.cpp work?
Date: 21 Oct 2002 13:34:55
Message: <1fe8ru03nn6kogrcu774op56dc4of4qo5s@4ax.com>
If it should return float then it can be also coded as internal function.
Check http://abx.art.pl/pov/patches/patches.php?Key=Internal+Functions for
tutorial how to do it.
ABX
Date: 21 Oct 2002 13:47:50
Message: <chrishuff-E24E4F.13430621102002@netplex.aussie.org>
You don't start with the small questions, do you... ;-)
Mainly, look at existing code for features that do something similar to
what you want, and imitate what you see.
That would be a lot easier.
Hmm...POV uses the position of the pattern ID in PATTERN_IDS (in
pattern.h) to tell block patterns from other patterns, so make sure you
put it with the "ordinary" patterns. The blend map stuff is handled
automatically. If you had it working right as a block pattern, you
probably added some code to the blend map parsing code that you need to
remove now...block patterns are actually more complex then float
patterns.
http://tag.povray.org/
Date: 22 Oct 2002 04:35:55
Message: <3db50dea@news.povray.org>
> struct *T;
Yes and btw *T.A.B is the same as *(T.A.B)
but if you need thm, they're useful. The better way is of course to
encapsulate them in a C++ class.
Thomas (still not thinking that hiding pointers like in Java is the right
way to go)
Date: 22 Oct 2002 11:30:11
Message: <web.3db56e012e88276b576e3f040@news.povray.org>
>> struct *T;
I start to understand ... ... slowly ...
please lemme 1st understand this C stuff ...
>way to go)
They're not really hidden ... It's just the pointer-arithmetic which isn't
allowed (IMHO for good reasons) and that all non-primitive types are given
by reference ...
But thx for the answer ...
Date: 23 Oct 2002 06:21:48
Message: <3db6783b@news.povray.org>
Then perhaps
P. Bothner und W-M Kaehler
Ohne C zu C++
Vieweg-Verlag
ISBN 3-528-05780-7
might offer a shortcut (but only in German AFAIK)
>>way to go)
> by reference ...
Some people keep saying that there aren't any pointers in Java...
Obviously you know better. If - as it seems - you know Java and German,
then my introduction to C++ on
http://www.inf.uni-konstanz.de/algo/lehre/skripte/
may also be of some help.
