POV-Ray : Newsgroups : povray.programming : What is the defination of "VECTOR" Server Time
30 Aug 2025 11:35:53 EDT (-0400)
  What is the defination of "VECTOR" (Message 1 to 5 of 5)
Subject: What is the defination of "VECTOR"
Date: 18 Oct 2002 11:31:06
Message: <3db0293a$1@news.povray.org>
Hi, all
   Where can I find the defination of "VECTOR"?
Thanks
Wu Yang
Subject: Re: What is the defination of "VECTOR"
Date: 18 Oct 2002 11:47:56
Message: <v3b0ru44oheu0hdrih37lo9t81p45g18c9@4ax.com>
On Fri, 18 Oct 2002 11:34:17 -0400, "Wu Yang" <wya### [at] cswrightedu> wrote:
> Hi, all
> Thanks
> Wu Yang
There is a section 'Scalar, color and vector stuff.' in frame.h
ABX
Date: 18 Oct 2002 11:51:59
Message: <3db02e1f$1@news.povray.org>
You should learn how to use VC++ or, if you're not using that, then your
operating system, to find files containing certain strings of text. Then you
could search for "#define VECTOR" or whatever corresponds to what you're
looking for.
 - Slime
[ http://www.slimeland.com/ ]
Date: 18 Oct 2002 12:18:49
Message: <3DB03468.8A747EBD@gmx.de>
> looking for.
Actually it's 'typedef DBL VECTOR [3];'.
None the less searching all POV-Ray source files often is a useful method
for finding things.  Either use 'grep' or the multiple file searching
function of your favorite editor.
Date: 18 Oct 2002 13:58:08
Message: <slrnar0ith.gc5.y7pt9001@safari.homelinux.net>
On Fri, 18 Oct 2002 18:18:48 +0200,
>> looking for.
I recommend global for those who don't know it already :)
http://ftp.funet.fi/pub/gnu/gnu/global/global-4.5.tar.gz
$ global -x VECTOR
VECTOR            812 frame.h        typedef DBL VECTOR [3];
Safari - y7p### [at] sneakemailcom
"Talk is cheap. Show me the code." - Linus Torvalds
