POV-Ray : Newsgroups : povray.programming : Proposal for 4.0 core control Server Time
30 Aug 2025 11:34:53 EDT (-0400)
  Proposal for 4.0 core control (Message 1 to 10 of 30)
Subject: Proposal for 4.0 core control
Date: 14 Oct 2002 11:47:24
Message: <3daae70c$1@news.povray.org>
Hello,
I am looking for feedback:
This documents is to explain most issues regarding a proposal for new,
additional hooks to significantly better abstract the POV-Ray 4.0 core code
from outside, platform specific implementation details. The goal is a much
more powerful connection with Graphical User Interfaces. These hooks offer
an optional way to specify the render options without a command line and
control rendering as well as replacements and additions for the text stream
based input and output.
Up to version 3.5 POV-Ray only allowed text output and the main control
worked through the command line. Since version 3.0 two more powerful GUI
platforms - Windows and Mac OS - provide text editors but little abstraction
of the command line. However, both platforms surely present the main part of
the POV-Ray users today and a command line environment is no longer state of
the art. Especially Integrated Development Environment applications outline
a reasonable way to move traditionally command line driven programs like
compilers into the GUI age. However, providing IDE like features without
extensive support from the backend, the POV-Ray platform independent core
code, is very hard and resulted in errors and a (today) rather primitive
user interface designs. These new hooks will ease the creation of GUIs on
other platforms as well.
The hooks are designed to be very flexible and extensible. They will allow
future changes in the core code without breaking platform specific code or
forcing changes in it. It can simply ignore the additional information and
immediate changes in platform specific code of all platforms if some hooks
are changed can be avoided in these areas.
In addition, the information about the current hooks is very limited and
some documentation would be helpful for both sides, the GUI as well as the
core code developers, in order to prevent breaking old code by new changes.
So there needs to be a document which contains the details of the POVOC&SS
functions, changes required in each platform specific code and composition
of the messages. It could be used as base for some kind of introduction for
those willing to port POV-Ray to unsupported platforms. With the constantly
increasing complexity of the hooks and other interface functions this has
become a more and more difficult task.
The POV-Ray Output Control & Streaming System (POVOC&SS) is a solution to
the command line and text input and output limitations for GUI systems. It
offers a very easy to extend control mechanism for POV-Ray. Existing command
line driven POV-Ray versions will only need little adjustment while the GUI
platforms may need (more) extensive changes in order to make use of the
newly available features and options. However, nearly full backward
compatibility is provided so GUI platforms do not need to be adapted
immediately.
The current test implementation uses linked lists and some automatically
resized arrays. This is not fast, but speed is not a major design goal,
flexibility is. There is no point to increase speed in most parts, i.e. it
does not matter (much) if an error message output takes 0.1 millisecond or
10 milliseconds.
Comments?
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: Proposal for 4.0 core control
Date: 14 Oct 2002 12:03:28
Message: <3DAAEAD0.B14A350B@gmx.de>
Thorsten Froehlich wrote:
> [...] The goal is a much
Hmm, sounds interesting, could you give a few examples what would be
possible with this system that does not work with current POV?  Your text
contains quite some information about principal technical aspects but not
about what things will be actually controlled with that 'POVOC&SS'.
Date: 14 Oct 2002 12:07:46
Message: <qaqlqu0vj236nmug0tljdt7bhl3269fhst@4ax.com>
On Mon, 14 Oct 2002 17:47:23 +0200, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> Comments?
Interesting reading. Nice opening for "more opened development" model. I have
to reread and reconsider carefully this whole statement. BTW: are there any
decision about GUI itself ? Similiar to those from 3.5 ?
ABX
Date: 14 Oct 2002 12:59:44
Message: <chrishuff-E2758E.12544714102002@netplex.aussie.org>
In article <qaqlqu0vj236nmug0tljdt7bhl3269fhst@4ax.com>,
 ABX <abx### [at] abxartpl> wrote:
> BTW: are there any decision about GUI itself ? Similiar to those from
> 3.5 ?
I'm not sure what your question is. The GUI itself is very platform
dependant, and will probably remain that way. There are cross-platform
frameworks, but those are pretty much equally bad on all platforms. ;-)
There will probably be similarities because they are designed to do the
same thing, and ideas will be shared, but I doubt there will be anything
like a standardized interface...
http://tag.povray.org/
Date: 14 Oct 2002 13:11:46
Message: <b0ulqu0c57po299ph1a0mpus9rt0ke3av4@4ax.com>
On Mon, 14 Oct 2002 12:54:47 -0400, Christopher James Huff <chr### [at] maccom>
> > 3.5 ?
I did not wrote "standarized" anywhere. I'm just wondering if codemax editor
would be continued in case of Win. But I understand my question is asked in
wrong time. There is no place for GUI decision right now. Anyway if you are
talking about "standardized interface" I'm thinking about making integrated
IDE for recently updated TVision (http://tvision.sf.net). Day after day it is
more portable and works with many compilers and could be nice optional layer
for many platforms. But I have not tested it yet. Just remember flexibility
from days of Borland ruling.
ABX
Date: 14 Oct 2002 14:42:33
Message: <3DAB10FF.8060807@starman.ee>
 > cross-platform frameworks, but those are pretty much equally bad on
 > all platforms. ;-) There will probably be similarities because they
 > are designed to do the same thing, and ideas will be shared, but I
 > doubt there will be anything like a standardized interface...
Why not? Why not to implement cross-platform UI by using some
(scriping??) language? I guess suppirting Windows/Linux/Unix/MacOS
should be sufficient and there is quite a number of tools for such task:
Tk/Tcl (or whatever it was called, never can't remember it :-), Python
(Yea, I know, that some here
hate Python, but Pyvon seems to be nice step in direction of
cross-platformness), Java with JNI for interface with POV-Ray core etc.
Performance of UI shouldn't be problem.
Date: 14 Oct 2002 14:51:50
Message: <3dab1246@news.povray.org>
In article <qaqlqu0vj236nmug0tljdt7bhl3269fhst@4ax.com> , ABX
Well, for a GUI the stuff that is available as part of Mozilla looks very
interesting.  Maybe increasing the level of abstraction and then just
running POV-Ray as a backend to a webbrowser might be sufficient.  After
all, there are plenty of editors out there, so no need for a dedicated
GUI...
    Thorsten
Date: 14 Oct 2002 14:55:49
Message: <3dab1335@news.povray.org>
In article <3DA### [at] starmanee> , Vahur Krouverk
Well, as far as a scripting language for 4.0 we have been considering to
allow functions written in Perl or maybe Scheme would be a good idea.  That
would make all those people happy who don't like the current scripting
capabilities.  And users could extend the GUI this way from inside POV-Ray
scene files.
    Thorsten
Date: 14 Oct 2002 15:04:25
Message: <chrishuff-C3BD98.14592714102002@netplex.aussie.org>
In article <3DA### [at] starmanee>,
> (Yea, I know, that some here hate Python, but Pyvon seems to be nice
> step in direction of cross-platformness), Java with JNI for interface
I covered that...the results are usually just horrible. Tune things to
look good on one platform, and it looks awful on all others...different
interface conventions, different look and feel, etc...you end up having
to make platform-specific versions anyway.
Date: 14 Oct 2002 15:07:57
Message: <3dab160d@news.povray.org>
In article <3DAAEAD0.B14A350B@gmx.de> , Christoph Hormann
Well, assuming some classes like below, one could remove user interface
dependincies from the core code and just allow overloading of a few classes
to transmit data...
    Thorsten
class Container
 public:
  Container();
  virtual ~Container();
  DataType DataType();
  long Size();
class List : public Container, public list<Container>
 public:
  List();
  List(List source);
  virtual ~List();
  void Append(Container item);
  void GetNth(int index, Container item);
  void SetNth(int index, Container item);
  void RemoveNth(int index);
  void Clear();
class Object : public Container, public map<DataType,Container>
 public:
  Object(DataType objclass);
  Object(Object convert);
  Object(Object source);
  ~Object();
  void Get(Container attr, DataType key);
  void Set(Container attr, DataType key);
  void Remove(DataType key);
  void Exist(DataType key);
class Status : public Object
 public:
  Status(string statusmsg);
  ~Status();
class Statistics : public Object
 public:
  ~Status();
class Warning : public Object
 public:
  ~Status();
class Error : public Object
 public:
  ~Status();
