POV-Ray : Newsgroups : povray.programming : Where can I find the reflected ray? Server Time
15 May 2026 19:15:18 EDT (-0400)
  Where can I find the reflected ray? (Message 1 to 10 of 14)
Subject: Where can I find the reflected ray?
Date: 11 Oct 2002 12:04:43
Message: <3da6f69b$1@news.povray.org>
Hi, all
    I am trying to write the reflected ray to a file. Firstly, I thought
that I could get the reflected ray from the reflect() function in
lighting.cpp file, so I wrote some code in the function to realize it, but
it did not work. I found that this function was not called when I pushed the
"RUN" button. I do not know the reason. Where can I find the reflected ray?
Thanks
Wu Yang
Subject: Re: Where can I find the reflected ray?
Date: 11 Oct 2002 12:38:03
Message: <chrishuff-4056A0.12344211102002@netplex.aussie.org>
In article <3da6f69b$1@news.povray.org>,
Silly question, but did you actually render a scene using reflection?
Just running the program won't call the Reflect() function, but it
sounds like that is what you are doing.
Are you sure the program is being compiled, and you aren't running an
unmodified version? What code are you using to write it to a file?
http://tag.povray.org/
Date: 13 Oct 2002 17:51:29
Message: <3da9eae1@news.povray.org>
Thank you for your reply. Yes, I think that the reflect() will be called
when I run the program. Why this is not right? I do modify what should be
changed and build the project without error. I define an "ofstream" object
"output" by
ofstream output("C:\\out.dat"); and run the program, but no out.dat formed.
Thank you for your assistant.
Best Regard
Wu Yang
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
but
the
ray?
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 13 Oct 2002 23:16:03
Message: <chrishuff-FD10B3.23110313102002@netplex.aussie.org>
In article <3da9eae1@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
The Reflect() function will only be called when POV is computing
reflection. Just running the program won't do that, you need to render a
scene with reflection. This is so obvious I can't believe you would be
doing otherwise, but you haven't given any indication of what exactly
you are doing other than "running the program", which isn't enough.
> I do modify what should be changed and build the project without
> error. I define an "ofstream" object "output" by ofstream
*Where* do you create the file? What is the *exact* code you are using
to create it and write the data? What is the scene file you are testing
it with?
Date: 13 Oct 2002 23:55:59
Message: <3daa404f@news.povray.org>
Is "box.pov" a scene with reflection. I do render it, but the reflect()
function is not called because I define an "ofstream" object "output" in
reflect() function. The exact code is "ofstream output("C:\\out.dat");".And
then render "box.pov",however, no "out.dat" formed. What's wrong?
Thanks a lot.
Best Regard
Wu Yang
> it with?
Date: 14 Oct 2002 00:14:24
Message: <3daa44a0@news.povray.org>
The exact code I write in reflect() function:
*                   lighting.cpp
#include <algorithm>
#include <fstream>
using namespace std;
static void Reflect(......)
  ofstream output("D:\\out.dat");
> it with?
Date: 14 Oct 2002 02:03:04
Message: <3daa5e12@news.povray.org>
  This is not an answer to your question per se, but do you think that's
the best way to go?
  If you open the file for writing each time Reflect() is called, this
is not only inefficient (a system call for opening a file for writing can
be quite slow if done lots and lots of times) but you will also be destroying
any previous data which existed in the file (by default ofstream opens
the file for writing, not for appending, ie. if the file existed already,
it's clamped to 0 size).
  You should only open the file once in some initialization routine, not
every time Reflect() is called.
  And by the way, it's a good idea to check if opening the file succeeded.
Don't take the success for granted.
Date: 14 Oct 2002 12:35:29
Message: <chrishuff-213708.12303114102002@netplex.aussie.org>
In article <3daa404f@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
No. It doesn't use reflection anywhere, which would be one reason no
files are written. Actually looking at the scene might have helped... ;-)
I'd suggest you use one of the demo scenes in scenes/textures/finishes/,
all of which do use reflection. And watch out, it could produce a huge
amount of data. I don't know what you want it for, it might be best to
make a very simple scene with one reflective shape to minimize the
amount of reflection data.
First, you are opening the file for every reflected ray. This will be
very slow, it would be better to open it once, for a temporary hack like
this it would be easiest to just use a global variable. Also, you are
opening it in write mode, it will overwrite the previously written data
every time, so you will never get a file with more than one entry. You
need to either open it once or open it in append mode. Opening the file
once in write mode and using a global variable for it would be the best
way: it will be much faster, and if you use append mode you will have to
remember to delete the data file before each render or it will just
append to what it wrote in previous renders.
And finally, you didn't give all the code. This is just the code for
opening a file, you didn't say how you are writing the data.
Date: 14 Oct 2002 13:56:07
Message: <3dab0537@news.povray.org>
Yes, I got it. Thank you very much. But I do not know why "box.pov" is
not a scene with reflection. I do see it. Why can I see it? The data for
displaying is what I want to get. Is it called light internsity?
   Actually, the code I post is the only code I wrote till now. I only want
to test if the reflect() function is called when I rend some pov file. Thank
you for your advice.
Best Regard
Wu Yang
Date: 14 Oct 2002 13:58:40
Message: <3dab05d0@news.povray.org>
Yes, you are right.
Thanks a lot
Best Regard
Wu Yang
news:3daa5e12@news.povray.org...
> the best way to go?
destroying
x]
Warp -
