POV-Ray : Newsgroups : povray.programming : Function based distortions of non isosurfaces Server Time
18 Dec 2025 00:39:02 EST (-0500)
  Function based distortions of non isosurfaces (Message 1 to 10 of 17)
Subject: Function based distortions of non isosurfaces
Date: 8 Oct 2002 20:18:09
Message: <3da375c1$1@news.povray.org>
I decided to give the current IRTC round a miss (I'm not good with nature
settings outside of Bryce) and play around with the POV-Ray code instead.
My goal was to allow mathmatic surface distortions of non isosurface objects
(aim low, I always say :). I ended up going the other way around, making an
object function that takes any object and makes it look like it's defined
mathematically for use in an isosurface, which you can then distort the
usual way. An example is thus:
#declare fn_my_box=
    function{
        object{
            Povray_Logo
The problem is, it's rather slow and I'd like some suggestions on how to
optimize it.
If you're interested in seeing sample images and a brief explanation of how
it works (how else can you offer optimization suggestions?) please follow
this rather obtuse link:
http://www.angelfire.com/weird2/gonk/povray/TwilightPOV/TW.html
Thanks!
- Jeff M. Thomas
jef### [at] twilightfaircom
Subject: Re: Function based distortions of non isosurfaces
Date: 8 Oct 2002 20:23:31
Message: <3da37703$1@news.povray.org>
This is cool and could be very helpful. (The CSG isosurface include file
does the same thing, but requires using a different syntax to create objects
with.)
Perhaps you can easily tell which direction the closest surface is in for
some primitives by using known facts about them. Spheres and cylinders, for
example, should be easy to do this for.
 - Slime
[ http://www.slimeland.com/ ]
Date: 8 Oct 2002 21:11:06
Message: <3da3822a@news.povray.org>
"Slime" <slm### [at] slimelandcom> wrote in message
news:3da37703$1@news.povray.org...
objects
> with.)
What CSG isosurface include? I didn't know there was one. Ack.
for
True, and I'd thought about that. But I like to avoid special casing for
object
types or dissecting CSGs if at all possible. If I can keep it coded to the
genral
case it should work for all object types now and into the future.
Thanks!
- Jeff
Date: 8 Oct 2002 21:13:49
Message: <3da382cd$1@news.povray.org>
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/
A built in solution would, however, be much more helpful.
 - Slime
Date: 8 Oct 2002 21:57:12
Message: <3da38cf7@news.povray.org>
> usual way.
  I don't understand how this can work in a general case (ie. with any
object and any CSG combination of objects) without some efficient
proximity function...
  Could you explain a bit more?
Date: 9 Oct 2002 00:09:22
Message: <3DA3AB7B.4D52A40E@mail.com>
Jeff -
I really like the images on your site.  I've thought about programming
something like this for a while, and what I finally landed on was this :
It would be useful to find the intersection with the object in the
ordinary way and then trace backward (or forward) from the intersection
point until the ray hits the "closest isosurface".  I don't know if that
is what you've done here, but it looks like it is similar.
To implement this method, you could declare an isosurface function as an
extra, specialized kind of Texture in the OBJECT_FIELDS definition, and
you could just modify All_Object_Intersections to look at this field and
trace the ray forward or backward after calculating the ordinary
intersection.
Is any of this useful?  I'm not sure, cause I haven't tried to implement
any of it yet...
- Ben Birdsey
Date: 9 Oct 2002 02:07:12
Message: <3da3c790$1@news.povray.org>
Well, I think the real proximity function is in the isosurface code which
I've left essentially unchanged. The Find Root functions have the onerous
task of locating the actual isosurface surface, as it were.
The object function itself simply uses brute force, shooting out rays until
it thinks it has a decent distance to return, which at this point simply
means it has one or more hits. Fortunately as the points get closer to the
object more rays hit and the results get more accurate. I don't pretend at
this point that it's optimal or even slightly efficient; frankly I'm rather
surprised how well it works the way it stands.
That's why I've asked for suggestions on optimizing the method, such as an
efficient proximity function for the general case :-).
Also I can't claim to have tested every possible case, just some relatively
complex CSGs with other object types. But since the code relies mostly on
the Intersection method I believe it should work with most general cases, if
not all.
Hope made sense,
- Jeff
Date: 9 Oct 2002 02:44:16
Message: <qgj7quotfhqgv5faomtvprd421eqdme434@4ax.com>
On Tue, 8 Oct 2002 23:19:31 -0700, "Jeff M. Thomas" <zaz### [at] yahoocom> wrote:
There is some proximity function in sources ???? I can't find such a keyword
in listing. I mean something like famouse proximity pattern ?
You should look sources of good old proximity pattern available in MegaPOV.
You can check additional parameters there were available to control finding
nearest intersection point. I think it is much better to have such an addition
as pattern. It could be placed in traditional texture with apropriate map.
Be sure you have readed all proximity related threads on this news server.
There were some further suggestions IIRC.
ABX
Date: 9 Oct 2002 09:41:09
Message: <3da431f4@news.povray.org>
  I see. That's the slow method (and sometimes inaccurate). :)
  It's basically what the proximity pattern in megapov does.
Date: 9 Oct 2002 10:07:58
Message: <3DA4383E.E24EED8A@gmx.de>
> #declare fn_my_box=
>     function{
>         object{
>             Povray_Logo
> optimize it.
As Slime mentioned you should have a look at the IsoCSG library.  Your
method seems to use about the same method as the proximity pattern in
megapov and therefore probably will be quite slow.  You can try to
optimize things but no matter what you try the calculations will almost
certainly never be as fast as with the mathematically exact proximity
function (which of course only exists for very few objects).
