POV-Ray : Newsgroups : povray.programming : exposure control woes Server Time
30 Aug 2025 19:46:17 EDT (-0400)
  exposure control woes (Message 1 to 4 of 4)
Subject: exposure control woes
Date: 22 Sep 2002 19:45:20
Message: <3d8e5610$1@news.povray.org>
I'm trying to implement logarithimic exposure control in 3.5, all was going
well until I tried large values for the exposure time, for some reason it is
clipping the colors really wierd and I'm getting strange black bands
everywhere. any thoughts as to why? If this isn't very clear I can post an
example pic on p.b.i
//The function
void Expose_Color (COLOUR Color, DBL Time)
 register DBL gray, expgray;
 gray = GREY_SCALE(Color);
 if(gray)
  expgray = 1-exp(-Time*gray);
  Color[pRED] = (expgray/gray) * Color[pRED];
  Color[pGREEN] = (expgray/gray) * Color[pGREEN];
  Color[pBLUE] = (expgray/gray) * Color[pBLUE];
//The call (render.cpp)
if(Frame.Exposure_Time)
  Expose_Color(Colour,Frame.Exposure_Time);
note: this is in 3.5
Kevin
#macro _(r)#if(r<12)#local i=asc(substr("oqshilacefg",r,1))-97;
disc{<mod(i,7)-3,div(i,7)-1,6>,z,.4pigment{rgb 10}}_(r+1)
#end#end _(1)//KL
Subject: Re: exposure control woes
Date: 23 Sep 2002 07:14:52
Message: <3D8EF7B8.A5596C82@luxlab.com>
>  if(gray)
The color channels are separate so try this:
Color[pRED] =   1-exp(-Time*Color[pRED]);
Color[pGREEN] = 1-exp(-Time*Color[pGREEN]);
Color[pBLUE] =  1-exp(-Time*Color[pBLUE]);
_____________
Kari Kivisalo
Date: 24 Sep 2002 14:07:29
Message: <3D90A9E7.8E9E3FCE@luxlab.com>
The clipping and black bands are caused by the grayscale conversion.
Some components will get values higher than one.
color = rgb<0.1,0,1>
gray = 0.3 * red + 0.59 * green + 0.11 * blue  (NTSC formula)
gray = 0.14
expgray = 1 - exp(-10*gray) = 0.75
expgray/gray * color.blue = 5.4
_____________
Kari Kivisalo
Date: 9 Nov 2002 05:27:35
Message: <3DCCE315.323FD54@luxlab.com>
Since you are not going to use the equations I suggested I will
make my own logarithimic exposure control patch from them.
_____________
Kari Kivisalo
