POV-Ray : Newsgroups : povray.programming : Need hints on POV-Ray's octree workings :) Server Time
2 Apr 2026 07:01:05 EDT (-0400)
  Need hints on POV-Ray's octree workings :) (Message 1 to 2 of 2)
Subject: Need hints on POV-Ray's octree workings :)
Date: 21 Sep 2002 14:18:39
Message: <3d8cb7ff$1@news.povray.org>
Hey all,
    I'm trying to wrap my mind around how POV-Ray uses the octree structure.
I've
done some reading on octrees, and have a decent mental picture of what they
are (I've even drawn diagrams for myself). However, I am getting stuck in
the
following areas:
1) What exactly do the OT_ID (in octree.h) data items x,y,z, and size
represent? Is x,y,z the the corner of the cube (node)? If so, which corner?
Similarly, does size represent the width of a cube in POV-Ray units?
2) As far as I can tell, POV-Ray uses the octree to store *points* in 3D
space (on the surface of objects) where the illuminance was sampled in
ra_gather(). All the octree tutorials I've read have the octree storing 3D
*objects*, not dimensionless points! I'm not
sure how to store a point in an octree. How does POV's octree select the
size of cube necessary to store a point? (which has no size)
Thanks for your help in getting me started :)
Sorry for posting in the wrong group initially!
George Pantazopoulos
Subject: Re: Need hints on POV-Ray's octree workings :)
Date: 21 Sep 2002 15:07:07
Message: <3d8cc35b@news.povray.org>
In article <3d8cb7ff$1@news.povray.org> , "George Pantazopoulos"
<the### [at] attbicom*KILLSPAM*> wrote:
> Hey all,
> I've
> the
> following areas:
No, not really.  I assume you saw the note at the top of octree.cpp?  And
now you are confused about the "pow(2,size-127)"?
Well, basically the "pow(2,size-127)" is also the reason why the 3.5.0 and
earlier radiosity only works on IEEE 754 floating point number format
supporting platforms.  So the size in essentially the mantissa of a floating
point number, which in turn is essentially the next lower power of two.
However, this number still has a bias of 127 because the code just takes the
signed value as unsigned value.  What exactly happens can be found out in
ot_index_box.
No, check out the functions ot_index_box and ot_ins.  Their comments and
actions should be fairly clear...
    Thorsten
e-mail: tho### [at] trfde
