POV-Ray : Newsgroups : povray.programming : a thought Server Time
11 Jul 2026 16:59:58 EDT (-0400)
  a thought (Message 1 to 2 of 2)
Subject: a thought
Date: 4 Sep 2002 09:48:29
Message: <3d760f2d@news.povray.org>
I've just realised, re my post, that if I could insert a piece of code to
disable right click in the exe file, I would have my problems solved also.
That way, when people open the exe file and are in it, if they try to get a
right click context menu they will right click and nothing happens. So does
anyoneknow where I could find a piece of code which I can append or insert
into my exe to do this?  I am able to view the compiled exe in a Hex Viewer,
so perhaps I could paste it in , in the Hex Viewer? Once again,
vag### [at] freedomusacom   - thanks people!
my original post I've pasted below, so you know of my problem:
I want to change a string displayed in an "About" box (not the owner bit,
other bits).  I dont have the program source code, only a compiled exe, and
I've done a simple text search in regedit (just the one under "edit, find"
in XP) which shows the info isn't there (after all, it's not info that's
meant to be changed or is specific to the user).
I know some basic programming asp, vb, c , tp etc  - but I'm a bit ignorant.
Can I somehow search the compiled exe for the text string (if it's in binary
or hex or something) and do a search and replace that way?  I know that the
exe came from code which was a mixture of vb, c and so on.
I noticed and passed by a hex tool on the web - probably can't find it
again.  I don't even know what level most little vb/c standalone programs
are compiled to. I mean, I don't know if it's 0s and 1s, or machine language
or whatever.  Any suggestions?
Subject: Re: a thought
Date: 5 Sep 2002 09:37:27
Message: <Xns92809EC0A5698PhiLho@204.213.191.226>
"bozo" <nos### [at] goawaycom> wrote in news:3d760f2d@news.povray.org:
> to disable right click in the exe file, I would have my problems
> solved also. That way, when people open the exe file and are in it, if
> they try to get a right click context menu they will right click and
> nothing happens. So does anyoneknow where I could find a piece of code
> which I can append or insert into my exe to do this?  I am able to
> view the compiled exe in a Hex Viewer, so perhaps I could paste it in
> , in the Hex Viewer? Once again, vag### [at] freedomusacom   - thanks
> people!
Mmm, I fail to see the relation between your original message and the
right click stuff.
I doubt you can hack an exe to disable right click. Unless you are a very
skilled cracker.
> bit, other bits).  I dont have the program source code, only a
> compiled exe, and I've done a simple text search in regedit (just the
> one under "edit, find" in XP) which shows the info isn't there (after
> all, it's not info that's meant to be changed or is specific to the
> user).
I wonder about the motivation of this, but I suppose/hope it is clean :-)
You may be interested by Resource Hacker
<http://www.users.on.net/johnson/resourcehacker/>, which allows to change
some parts of the GUI.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
