POV-Ray : Newsgroups : povray.programming : [PATCH] use boundings for inside testing Server Time
20 Dec 2025 01:20:31 EST (-0500)
  [PATCH] use boundings for inside testing (Message 1 to 1 of 1)
Subject: [PATCH] use boundings for inside testing
Date: 3 Aug 2002 07:43:27
Message: <3d4bc1de@news.povray.org>
First I show an example where what for the patch is good. Consider the
menger fractal constructed as follows:
macro menger(l,d)
 #if (d>0)
  #local p = menger(l/3,d-1) union{
  #declare ix=-1; #while(ix<2)
   #declare iy=-1; #while(iy<2)
    #declare iz=-1; #while(iz<2)
     #if ((ix!=0 & iy!=0) | (iy!=0 & iz!=0) | (ix!=0 & iz!=0))
      object{p translate <ix,iy,iz>*l/3}
    #declare iz=iz+1; #end
   #declare iy=iy+1; #end
  #declare ix=ix+1; #end bounded_by{box{-l/2,l/2}}}
 #else sphere{0,l/2} #end
#declare myplane = plane{x,0 translate<-6,0,0> rotate <0,90,0> rotate
<45,-20,0>}
intersection{
 object{menger(4,3) rotate <20,30,0> translate <0,0,10>}
 object{myplane} // *
 pigment{rgb 1}
light_source{<-100,200,-20>,1 }
This needs about 250s to render and the statistics say
Box                            1417965          164676     11.61
CSG Intersection                 82765           13615     16.45
CSG Union                       164676          131410     79.80
Plane                            82765           81320     98.25
Sphere                         1958320          105681      5.40
Bounding Object                1417965          164676     11.61
But if you remove the line markes with an '*' it only needs 2 seconds and
gives:
Box                            1422461          161254     11.34
CSG Intersection                 83741           17944     21.43
CSG Union                       161254          122553     76.00
Sphere                         1886360          100982      5.35
Bounding Object                1422461          161254     11.34
You see that the number of test are nearly the same. Why does it take so
much longer then? Each time a ray hits the plane it tests if the
intersection point is inside the menger fractal. But it seems to do this
for *each single sphere*.
My patch changes this. It first tests if the point is inside the bounding.
If it is NOT then it knows that it can already decide that the point is
outside (if the object IS NOT inversed) or that the point is inside (if the
object IS inversed).
Therefore with my patch applied it needs only 2 seconds to render for *both
cases*.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Download 'us-ascii' (1 KB)
Subject: Re: [PATCH] use boundings for inside testing
Date: 4 Aug 2002 06:51:37
Message: <3d4d0739@news.povray.org>
Addendum:
The patch tests only additional boundings, that is only when 'bounded_by'
is used. So the effect on everyday-scenes will likely be small. It could be
extended to test the automatic-generated BoundingBox as well. But
unfortunately POV-Ray does not generate a boundingbox-hirarchy with
merge/intersections.. I do not really see why.
- Micha
