POV-Ray : Newsgroups : povray.programming : bounced light Server Time
18 Dec 2025 20:47:29 EST (-0500)
  bounced light (Message 1 to 5 of 5)
Subject: bounced light
Date: 8 Apr 2002 11:58:11
Message: <3cb1be13@news.povray.org>
Is anyone working on enhancing the povray raytrace engine to allow for real
bounced light. Light that when it strikes an objects bounces off to go on
and illuminate other objects. I know radiosity is a way of achieving this
look but it seems rather week. I have been trying to create scenes where the
light is outside of a structure but the image is inside. Like a cave. Or a
room with the sun high in the sky. If this is possible already how? and to
what quality.
I have looked at a large number of rendering engines and I find this ability
only in high priced products and even then it if faked with lighting tricks.
I am not too worried about speed either.
Thanks very much for all of you very hard working programmers.
Mike Williams
IBO# 770070
www.quixtar.com
Subject: Re: bounced light
Date: 8 Apr 2002 12:35:56
Message: <3CB1C6EA.B1BEDC68@gmx.de>
> what quality.
Radiosity and photon mapping are the most common methods for doing this.
I don't know any popular rendering software using a different method
(apart form using finite element radiosity instead of monte carlo
techniques - something not possible in Povray for principal reasons)
For your examples Megapov/Povray 3.5 radiosity should lead to quite
acceptable results.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 10 Apr 2002 03:26:44
Message: <3cb3e934@news.povray.org>
If this is really true, then try WinOSI ... this will do ...
Date: 12 Apr 2002 15:48:56
Message: <3cb73a28$1@news.povray.org>
If you're using 3.5 try increasing recursion_limit.  This might help (it
generates more bounced rays).  If it's reflective use photons too.
__________________
 RAY
"Mike Williams" <mwi### [at] morninglightmediacom> wrote in message
news:3cb1be13@news.povray.org...
real
the
> what quality.
ability
tricks.
> Mike Williams
> IBO# 770070
> www.quixtar.com
Date: 16 Apr 2002 20:25:19
Message: <3cbcc0ef$1@news.povray.org>
Yes, in the cavity-type scenes I've rendered (such as a room with a single
window admitting light, or a cave), you really need to set recursion_limit
above 2. I typically use a recursion_limit of 7 in such scenes. I also have
gone up to 12 and seen quite a visible difference, but around 5-9 usually
works well.
George Pantazopoulos
"RAY" <RAY### [at] yahoocom> wrote in message
news:3cb73a28$1@news.povray.org...
> __________________
>  RAY
> real
on
this
> the
a
to
> > what quality.
> ability
> tricks.
> > Mike Williams
> > IBO# 770070
> > www.quixtar.com
