POV-Ray : Newsgroups : povray.programming : POV-reg entries=? Server Time
11 Jun 2026 19:46:48 EDT (-0400)
  POV-reg entries=? (Message 1 to 10 of 20)
Subject: POV-reg entries=?
Date: 6 Nov 2001 17:48:26
Message: <3be868ba$1@news.povray.org>
Is there either a way to run POV without having actually run the install
program (i.e all program files but no registry entries) or an unofficial
compile that doesn't use the reg. entries? I'd like to be able to use POV at
school, but the security won't allow registry changes.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: POV-reg entries=?
Date: 7 Nov 2001 00:52:10
Message: <3be8cc0a$1@news.povray.org>
Mahalis wrote in message <3be868ba$1@news.povray.org>...
at
SkyPOV ( http://www.geocities.com/Rengaw03/povray.html ) can work without
the registry entries.  I developed it on my university's computers, and for
some reason, the install program won't run on them, so the registry entries
couldn't be set up.
Mark
Date: 7 Nov 2001 01:29:02
Message: <3BE8D4AF.D187F1B@gmx.de>
The Cygwin version does not need registry entries, but be aware it's just
text mode and also usually slower than the GUI version:
http://www.schunter.etc.tu-bs.de/~chris/povcyg/index.html
Date: 7 Nov 2001 07:12:10
Message: <3be9251a$1@news.povray.org>
Thank you. It still retains all the regular POV features, correct?
//Mahalis
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3be8cc0a$1@news.povray.org...
> at
for
entries
> couldn't be set up.
> Mark
Date: 7 Nov 2001 07:46:20
Message: <c1biut0kiurh2m60n53fudihsnnd6jm7lq@4ax.com>
On Wed, 07 Nov 2001 07:29:03 +0100, Christoph Hormann <chr### [at] gmxde>
And what is most important there is no (published) version of it for POV 3.5 *)
*) of  course I know it is beta time but it could allow test some slower
features on faster machines in my company without agresive changing enviroment
(they are important machines)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 7 Nov 2001 08:50:13
Message: <3be93c15$1@news.povray.org>
It says it needs MegaPOV or POV 3.1 installed (and it also seems to want
that annoying HOME= entry in the registry), but the reason I was looking for
this kind of thing in the first place was because I couldn't run the install
program.
//Mahalis
> at
for
entries
> couldn't be set up.
> Mark
Date: 7 Nov 2001 11:54:39
Message: <3BE96750.E2C0E859@gmx.de>
BTW, it could turn out to be more difficult that you may think, the
-mno-cygwin flag only works with C and not C++ so you will either have to
use the Cygwin DLL (which would be problematic for a binary release) or
use the MinGW gcc instead.
Date: 7 Nov 2001 11:56:40
Message: <2tpiutotp1to2auo1lhkklj5j878p9fbs6@4ax.com>
On Wed, 07 Nov 2001 17:54:40 +0100, Christoph Hormann <chr### [at] gmxde>
have you tested DJGPP ?
ABX
Date: 7 Nov 2001 12:52:52
Message: <3BE974F2.D470F264@gmx.de>
No, but AFAIK that's a DOS port of gcc, not exactly what would be useful
here.
Date: 7 Nov 2001 13:17:52
Message: <3be97ad0@news.povray.org>
I'm not sure what you are talking about (is 3.5 written in C++?), but
compiling the "povcyg" version with mingw instead of cygwin is no problem, I
only had to change the pathes in the makefile..
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
