POV-Ray : Newsgroups : povray.programming : i search 3D algorythms Server Time
29 Sep 2024 10:16:12 EDT (-0400)
  i search 3D algorythms (Message 1 to 8 of 8)
Subject: i search 3D algorythms
Date: 25 Oct 2001 18:57:38
Message: <3bd898e2@news.povray.org>
Hi everybody
i search 3D algorythms to make a 3Dmodeler and a simply 3D scanner.
do anybody know where i can found it?
Subject: Re: i search 3D algorythms
Date: 26 Oct 2001 04:03:59
Message: <7r5ittkg4404o653551ne4rp9h9gvgsdos@4ax.com>
On Fri, 26 Oct 2001 00:59:15 +0200, "3dsman" <3ds### [at] freefr> wrote:
> Hi everybody
Hi
There is a lot of algorythms about it. Please specify what are you
looking for?
You can find a little about it within documentation for POV 3.5
Just follow right links on top bar:
http://www.povray.org/working-docs/id000107.html#4_2
What you mean: 3D scanner ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 26 Oct 2001 16:43:43
Message: <3bd9caff@news.povray.org>
> looking for?
whow i dont speak english very well but i will:
i want to make a 3Dmodeler which make meshes so i search algorythms to
smooth meshes, make booleans operations, fill meshe's hole.
and for the scanner i must find algo to join two meshes correctly.
thank you
i've used a projector to project ray on the object to scan and i take a
photograph of it.
i've programing a soft which create meshe from this picture (it's not yet
automatic) but this software cant join two meshes and haven't opengl
preview. I'm working on this last point but i can't find how i can do this!
You can see exemple on my scanner website: http://3dsman.free.fr/freescan3D/
Date: 27 Oct 2001 03:29:28
Message: <cm4kttk913ucgl6ptbjmki5sqtf4ip36cg@4ax.com>
Launch your favorites search engine and search for "image based
rendering." There are various methods to reconstruct 3D geometry from
photograph of an object or scene.
Peter Popov ICQ : 15002700
Date: 27 Oct 2001 10:40:30
Message: <8ftktt4v6n1skvdvfnpo9b6al2fcknd2l9@4ax.com>
Here's some advice:
1. Go to http://graphics.stanford.edu/ and check their publications,
there has been quite a lot of work done on geometry reconstruction
2. Go to http://www.siggraph.org/ and check there.
3. You might have some luck on the ASME or IEEE websites, www.asme.org
and www.ieee.org
4. Lastly, if you're having problems posting in English, there is a
newsgroup on this server called povray.international (it was launched
a few days ago so you might need to refresh your groups list). Post
your question in French there, just indicate that in the subject line
like this:
Subject: [fr] I search 3D algorithms
I hope this information will give you some starting point.
Date: 29 Oct 2001 09:51:04
Message: <3bdd6cd8@news.povray.org>
my mesh is already made! i just want to join two meshes in one.
Date: 29 Oct 2001 09:57:21
Message: <vfrqttouhhgcvrj4ptpna80i7bdaua8cu5@4ax.com>
but what do you mean by that ? can't you just join data structures ?
ABX
Date: 30 Oct 2001 04:45:48
Message: <stssttsqrjtobn32v3uaitle4tr3im6h9g@4ax.com>
You mean like pasting an arm on Venus of Milo?
Well, the points I made are still valid, Stanford, MIT and SIGGRAPH
are your best bet as far as I can tell. Unfortunately, this is not my
field by far so I can't really recommend authors or papers, but I'm
sure that with the proper keywords you'll find what you need.
