POV-Ray : Newsgroups : povray.programming : Programming Help Wanted Server Time
15 May 2026 21:17:43 EDT (-0400)
  Programming Help Wanted (Message 1 to 4 of 4)
Subject: Programming Help Wanted
Date: 10 Sep 2001 18:16:38
Message: <3b9d3bc6@news.povray.org>
Hi all
Can anyone help me with the following?
I want to be able to read in an image and store the colour information for
each pixel in an array.
#declare ImageArray = array[ImageWidth][ImageHeight][3] // 3 = RGB
As far as I can see this could be done with the File I/O functions in POV,
but I don't know enough to be able to write what is needed to decode an
image format and populate the array.  I'm not too bothered about which image
format is used as it's easy enough to convert as required.
Any help with this will be most appreciated, and of course credited where it
is used:)
Thanks in advance
Michael
Subject: Re: Programming Help Wanted
Date: 10 Sep 2001 19:27:37
Message: <3b9d4c69@news.povray.org>
michael.k <mic### [at] ntlworldcom> wrote:
: As far as I can see this could be done with the File I/O functions in POV,
  Nope, it's not possible to read a binary file (nor even most ascii files)
with POV-Ray file I/O. POV-Ray can only read ascii files with certain structure
(mainly POV-Ray compatible items separated with commas).
Date: 10 Sep 2001 19:36:13
Message: <3b9d4e6d@news.povray.org>
However, you can achieve this by using pigment functions.
  This is an example which supposes that "image.png" is 160x120:
#declare Image =
  function
  { pigment { image_map { png "image.png" } }
#default { finish { ambient 1 } }
union
{ #declare IndY = 0;
  #while(IndY < 120)
    #declare IndX = 0;
    #while(IndX < 160)
      #declare Color = Image(IndX/160, IndY/120, 0); // The trick
      box { <IndX,IndY,0><IndX+1,IndY+1,1> pigment { color Color } }
      #declare IndX = IndX+1;
    #declare IndY = IndY+1;
  translate <-160/2, -120/2>
  scale 1/160
camera { location -z look_at 0 }
Date: 11 Sep 2001 19:13:35
Message: <3b9e9a9f@news.povray.org>
Thanks Warp
This is exactly what I wanted to do.
Michael
Warp <war### [at] tagpovrayorg> wrote in message news:3b9d4e6d@news.povray.org...
> #declare Image =
>   function
> union
>   #while(IndY < 120)
>     #declare IndX = 0;
>     #while(IndX < 160)
>     #end
>   #end
>   scale 1/160
