POV-Ray : Newsgroups : povray.programming : trace in function Server Time
11 Nov 2025 22:11:48 EST (-0500)
  trace in function (Message 1 to 8 of 8)
Subject: trace in function
Date: 10 Sep 2001 03:25:46
Message: <3b9c6afa@news.povray.org>
i know it s too late for pov3.5 but maybe an idea for futur patches : what
about adding a "trace function" for functions ? something like
ftrace(start,dir,object) which return 1 if the ray intersect "object" and
else 0 . This would allow a visibility pattern , a projection pattern , etc
M
Subject: Re: trace in function
Date: 11 Sep 2001 01:14:25
Message: <3b9d9db1@news.povray.org>
Mael wrote in message <3b9c6afa@news.povray.org>...
What could this do that "trace()", which is in POV 3.5, can't do?
Mark
Date: 11 Sep 2001 01:26:14
Message: <slrn9pr83q.hlh.ron.parker@fwi.com>
Be used in functions.
Unfortunately, that doesn't work.  By the time a function gets parsed, the
#declared object you passed to trace() has been returned to the bit-bucket.
This would be a major change.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 11 Sep 2001 03:00:21
Message: <Xns91195B9CF3494seed7@povray.org>
> parsed, the #declared object you passed to trace() has been
> returned to the bit-bucket. This would be a major change.
And what if it just works with the object that currently is ray-traced,
not with a declared object?
sphere {
  0,1
    function {
      select(trace(...), ..., ...)
    colour_map {
Gives some result on the first object-ray intersection that can be used
in the pigment calculation
Ingo
Date: 12 Sep 2001 06:05:47
Message: <3B9F3515.160AF1EA@reading.ac.uk>
Ron Parker wrote:
[snip]
[snip]
And yet you can use the 'object' pattern in a function? Sorry if I'm
being dense, but doesn't this use much of the same information?
Maybe when I can look at the v3.5 source code I'll see just how silly a
question that is ... :-(
Mike Andrews.
Date: 13 Sep 2001 04:46:52
Message: <3ba0727b@news.povray.org>
Michael Andrews <M.C### [at] readingacuk> wrote:
: And yet you can use the 'object' pattern in a function?
  I think that you just gave inavertetly the solution to the original question.
Date: 13 Sep 2001 07:08:02
Message: <3ba09392$1@news.povray.org>
question.
some times ago i wrote a little patch for megapov
(http://195.221.122.126/tmp/), mainly to learn about pov sources, and i
programm a projection pattern (http://195.221.122.126/tmp/projection.html) .
Do you mean we can achieve the same results with the object pattern ? how ??
M
Date: 13 Sep 2001 07:48:08
Message: <3ba09cf8@news.povray.org>
Mael <mae### [at] hotmailcom> wrote:
:>   I think that you just gave inavertetly the solution to the original
: question.
  Hmm... It seems that I confused two concepts (object interior and ray-object
intersection) in my mind. Perhaps because so many things have happened
lately and I'm not fully concentrated...
  Just forget my comment.
