POV-Ray : Newsgroups : povray.programming : Weird blackness under glass object Server Time
29 Sep 2024 10:15:06 EDT (-0400)
  Weird blackness under glass object (Message 1 to 3 of 3)
Subject: Weird blackness under glass object
Date: 13 Jun 2001 12:21:03
Message: <3b2792ef$1@news.povray.org>
I have a simple glass disk (cylinder) lying on a white surface, and rather
than appearing clear, there's a bunch of black 'noise' appearing under the
disc. Seems like a max_trace_level problem, but I cranked that up into the
hundreds with no success. If I move the disc up the tiniest fraction so it
hovers above the surface, it appears fine, seems like some surface
interaction or something. Any  ideas? Running on Win2K, 650MHz, 392M RAM,
POV-Ray Version 3.1g.watcom.win32. Here's the scene code, any ideas? Is this
a bug?
#version 3.1
#include "glass.inc"
global_settings {
   max_trace_level 7
camera
  location  <0, 15, -80>
  look_at   <0,  2, 0>
  angle 7
light_source
  <100, 90, -60> color rgb 2
plane
{ y, -1.0
  texture
  { pigment { color Brown*1.3 }
    finish {reflection 0.2}
box
  <-2,-1,6><300, -0.00, -400>
  texture { pigment { color White*0.9 } }
#declare Blue_Glass =
    pigment { color rgbf <0.96, 0.96, 1.5, 0.9>  }
    finish { F_Glass3 }
cylinder{
  <0,0,0><0,0.3,0>,1.8
  texture{Blue_Glass}
Subject: Re: Weird blackness under glass object
Date: 13 Jun 2001 12:30:32
Message: <slrn9if599.bk4.ron.parker@fwi.com>
>a bug?
See http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#blackspots
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 16 Jun 2001 15:02:00
Message: <chrishuff-43AADF.14015116062001@povray.org>
This is just a coincident surfaces problem...the solution is to move the
disc up slightly. It is not a bug.
BTW, this group is for discussions about programming, specifically about
the POV-Ray source code, not for scene file help. Your question would
have been better put in povray.newusers.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
