POV-Ray : Newsgroups : povray.programming : Re: converting an old Halo Server Time
30 Sep 2024 12:13:13 EDT (-0400)
  Re: converting an old Halo (Message 1 to 2 of 2)
Subject: Re: converting an old Halo
Date: 10 Mar 2001 00:21:22
Message: <3aa9b9d2@news.povray.org>
The group povray.programming is for discussing the source code of
POV-Ray, not the scene description language.  Follow-ups to
povray.newusers please.
     Thorsten
In article <3aa9b3cc@news.povray.org> , "John M. Dlugosz"
<joh### [at] dlugoszcom> wrote:
> Could someone with immediate knowledge of this feature help me out and tell
> me the equivilent statement in the current POV version?
> See http://www.dlugosz.com/Artwork/POV/lamp1.JPG for the picture: this is
> your basic glowing effect.
> TIA,
> --John
> light_source {
>     <0,0,0>
>     color White
>     looks_like {
>         sphere { 0, 1
>             pigment { color rgbt <1, 1, 1, 1> }
>             halo {
>                 emitting
>                 spherical_mapping
>                 linear
>                 color_map {
>                     [ 0.0 color rgbt <1, 1, 0, .999999> ]
>                     [ 0.5 color rgbt <1, 1, 0, 0.5> ]
>                     [ 0.8 color rgbt <1, 1, 1, 0> ]
>                     [ 1.0 color rgbt <1, 1, 1, 0> ]
>                 samples 10
>             hollow
>             scale <3,1.5,1.5>
>             } //end sphere
>         } // end looks_like
>     translate y*9.7
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 10 Mar 2001 01:18:53
Message: <3aa9c74d@news.povray.org>
tell
is
> > light_source {
> >     <0,0,0>
> >     color White
> >     looks_like {
> >         sphere { 0, 1
> >             halo {
> >                 emitting
> >                 spherical_mapping
> >                 linear
> >                 color_map {
> >                 samples 10
> >             hollow
> >             scale <3,1.5,1.5>
> >             } //end sphere
> >         } // end looks_like
> >     translate y*9.7
This might be about right:
#declare D=.75;
sphere {0,1
        pigment {rgbt 1}
interior {
    media {
        intervals 6
        samples 30,30 // method 2 // use less intervals and samples in
MegaPOV
        emission <1,1,0>
            density {
                spherical
        density_map {
            [0 rgb<1,1,0>*0*D]
            [.5 rgb<1,1,0>*.5*D]
            [.8 rgb<1,1,1>*D]
            [1 rgb<1,1,1>*D]
  scale <3,1.5,1.5>
 hollow
MegaPOV allows for much faster renders with method 2 used in the media
statement while also keeping it smoother with less samples (and intervals).
However unequal min and max samples is usually grainy.
Bob H.
Date: 10 Mar 2001 21:54:06
Message: <3aaae8ce$1@news.povray.org>
Thanks for the quick fix.  I suppose I can play with the map to get the
gradiation just right... but, puzzle me this:
1) textures look different, such as the floor.
2) the light is backwards!  In the new image, there is a bright stripe from
lower-left to mid-right along the floor, when in the original it's a dark
shadow.  Huh??
See the render at http://green.dlugosz.com/files/lamp1.3.jpg and you can
find the source file at lamp1.3.pov in the same path.
I used MegaPOV 0.4a and did enable it in the source.  I get the same result
if I comment out the "version unofficial".
TIA,
--John
"Bob H." <omn### [at] msncom> wrote in message
news:3aa9c74d@news.povray.org...
> tell
> is
> > > light_source {
> > >     <0,0,0>
> > >     color White
> > >     looks_like {
> > >         sphere { 0, 1
> > >             halo {
> > >                 emitting
> > >                 spherical_mapping
> > >                 linear
> > >                 color_map {
> > >                 samples 10
> > >             hollow
> > >             scale <3,1.5,1.5>
> > >             } file://end sphere
> > >         } // end looks_like
> > >     translate y*9.7
> #declare D=.75;
> sphere {0,1
>         pigment {rgbt 1}
> interior {
>     media {
>         intervals 6
> MegaPOV
>         emission <1,1,0>
>             density {
>                 spherical
>         density_map {
>             [0 rgb<1,1,0>*0*D]
>             [.8 rgb<1,1,1>*D]
>             [1 rgb<1,1,1>*D]
>   scale <3,1.5,1.5>
>  hollow
intervals).
> Bob H.
