POV-Ray : Newsgroups : povray.programming : Parsing an object Server Time
11 Jun 2026 21:04:12 EDT (-0400)
  Parsing an object (Message 1 to 10 of 13)
Subject: Parsing an object
Date: 17 Jan 2001 09:17:21
Message: <3a65a971@news.povray.org>
Just noticed that my tesselation patch supports object identifiers but
not objects directly. That is, I can write:
tesselate { MyObject }
but I can't write, for example:
tesselate { object { MyObject scale 2 } }
  Although this alone seems irrelevant (because you could perfectly put the
transformations in the tesselate block instead of the object block), it's
more relevant when using the tesselation block inside meshes (because you
can tesselate the same object several times into the same mesh). For example
this way:
mesh
{ tesselate { object { MyObject translate y } }
  tesselate { object { MyObject rotate z*180 translate -y } }
  How should I parse that so that it would accept any form of an object and
not just object identifiers?
  I'm currently parsing it this way:
    EXPECT
      CASE (OBJECT_ID_TOKEN)
        Object = Token.Data;
      END_CASE
      ... (parsing of the other allowed keywords here) ...
      OTHERWISE
        UNGET
        EXIT
      END_CASE
    END_EXPECT
  How should I modify that?
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Subject: Re: Parsing an object
Date: 17 Jan 2001 09:25:39
Message: <slrn96bar4.et0.ron.parker@fwi.com>
Call Parse_Object, which will return a pointer to an OBJECT or NULL if
one wasn't found.  If you absolutely want the object to be able to appear
anywhere inside the curly braces, as it can in your code below, you will
want to call Parse_Object between the UNGET and the EXIT in your OTHERWISE
clause.  However, I recommend calling Parse_Object before your EXPECT loop
and just requiring it to be the first thing inside the curly braces.
Also, since Parse_Object already recognizes OBJECT_ID_TOKENs as objects,
you can remove that CASE.
Remember to free up the object when you're done with it (even if it was
an object ID; Parse_Object makes a copy.)
>    EXPECT
>      END_CASE
>      OTHERWISE
>        UNGET
>        EXIT
>      END_CASE
>    END_EXPECT
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 17 Jan 2001 09:41:12
Message: <3a65af08@news.povray.org>
Warp wrote in message <3a65a971@news.povray.org>...
just like Ron Parker said : OBJECT *Parse_Object()
btw: is there automatic inheriting of parameters such like texture, no_shadow,
etc.?
I mean in tesselation patch.
ABX
Date: 17 Jan 2001 09:49:08
Message: <chrishuff-8D3D07.09501117012001@news.povray.org>
In article <3a65a971@news.povray.org>, Warp <war### [at] tagpovrayorg>
>       END_CASE
I don't have the source code open right now, but if the object data
sticks around past the parse stage, this will be a problem. You should
probably use Parse_Object(), as Ron said...then just delete it when you
aren't using it any more.
Christopher James Huff
Date: 17 Jan 2001 10:07:50
Message: <3a65b545@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Call Parse_Object, which will return a pointer to an OBJECT or NULL if
: one wasn't found.
  Ok, thanks. That's exactly it.
: Remember to free up the object when you're done with it (even if it was
: an object ID; Parse_Object makes a copy.)
  Hmm... How is it freed? Just POV_FREE(Object)?
Date: 17 Jan 2001 10:08:58
Message: <3a65b58a@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote:
: btw: is there automatic inheriting of parameters such like texture, no_shadow,
: etc.?
: I mean in tesselation patch.
  The tesselation patch makes a Parse_Object_Mods((OBJECT*)tesselationMesh)
after creating the mesh.
  I don't know if that's what you mean.
Date: 17 Jan 2001 10:20:34
Message: <slrn96be24.eus.ron.parker@fwi.com>
Destroy_Object.  See objects.c for parameters.
Date: 17 Jan 2001 10:30:28
Message: <3a65ba93@news.povray.org>
I have run into one problem. I get a:
error: Attempt to malloc zero size block (File: parse.c Line: 4385).
  This line is inside the Parse_Mesh() function and is the following:
  Object->Data->UVCoords = (UV_VECT *)POV_MALLOC(number_of_uvcoords*sizeof(UV_VECT),
"triangle mesh data");
  It unconditionally allocates space for uv-coordinates even if
number_of_uvcoords is 0 (as it is in my case where I only create triangles
with the tesselation function).
  Shouldn't it be enclosed in an if(number_of_uvcoords)?
  Will I break something if I add that condition?
  Why it doesn't crash with regular meshes (without uv-coordinates)?
Date: 17 Jan 2001 10:39:04
Message: <3a65bc97@news.povray.org>
:   Will I break something if I add that condition?
  Probably. I get a bus error, core dumped when I try to render a
tesselated mesh created this way (povray crashes when the rendering
process reaches the mesh).
  There's probably something with that uv-coord info that I don't take
into account. What is it?
Date: 17 Jan 2001 10:41:50
Message: <slrn96bfa0.eus.ron.parker@fwi.com>
This sounds like a question for p.u.p.
