POV-Ray : Newsgroups : povray.programming : still about povray source code Server Time
29 Sep 2024 12:17:06 EDT (-0400)
  still about povray source code (Message 1 to 7 of 7)
Subject: still about povray source code
Date: 11 Dec 2000 06:22:22
Message: <3a34b8ee@news.povray.org>
I want add/ask something
first:
why assign_XXXXs (vector , matrices) with memcpy
are not used in functions from matrices.c ?
as I remember from assembler, loops with assigment
are slower than fast memory transfer
second:
perhaps this is not important for advenced pov-programmers but...
All_XXX_Intersections()
why this not return ALL if there is ALL in name ?
is this proper name for function?
for beginner this makes trouble, belive me :-)
ABX
Subject: Re: still about povray source code
Date: 11 Dec 2000 07:41:01
Message: <slrn939iqv.tqq.ron.parker@fwi.com>
It should return all, but meshes and some other objects are exceptions to
the rule, usually for speed considerations.  Anything you can use in CSG
should definitely return all.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 11 Dec 2000 08:00:01
Message: <3a34cfd1@news.povray.org>
Ron Parker wrote in message ...
hmm, but everything returns only positive vales of depth
this isn't all
ABX
Date: 11 Dec 2000 08:19:10
Message: <slrn939l2g.ts4.ron.parker@fwi.com>
>this isn't all
Sure it is.  "All intersections" means "all intersections of the object with
a ray."  Since a ray goes only one direction from a point, all of the
intersections with that ray will be in a positive direction.
Date: 11 Dec 2000 08:29:45
Message: <3a34d6c9@news.povray.org>
>>this isn't all
> a ray."
unfotunatly I didn't found such comment in code
sure, I understand idea
but unfotunatly when I sit to code I consider ray as line
as I said this is annoying only for beginner :-(
ABX
Date: 11 Dec 2000 10:27:31
Message: <3a34f263$1@news.povray.org>
In article <3a34d6c9@news.povray.org> , "Wlodzimierz ABX Skiba"
>> a ray."
Doesn't the function take a "Ray" as argument?
This might have to do with that fact that POV-Ray is something called a
"ray-tracer", not a "line-tracer" ;-)
   Thorsten
Date: 11 Dec 2000 12:28:09
Message: <3a350ea9@news.povray.org>
Thorsten Froehlich wrote in message <3a34f263$1@news.povray.org>...
>>> a ray."
sure, trivial, simple ?
parametric equation of line is exactly ray equation
vector structure is used for both: vectors and points
I thought at first that for csg operation
this always return all intersections and only filter it later
oh, common! I just forgot ;-)
ABX
