POV-Ray : Newsgroups : povray.programming : complete animation language Server Time
29 Aug 2025 23:18:58 EDT (-0400)
  complete animation language (Message 1 to 9 of 9)
Subject: complete animation language
Date: 25 Mar 2003 04:47:22
Message: <3E8023BD.5080107@nodomain.com>
Hi guys, has anyone ever thought of merging povray with a music
description language?
I mean, to have a language that generates movies with sound. We can sync
the sound together with our animation using an SDL (with support for sound).
Is there a language that does this already? That generates 3D animation
with sound from a scene description?
The thing I imagined would be something like this:
sphere {
   0, 1
   translate <12, 0, 0> * clock
     color rgb 1
sound {
   wav "background.wav"
   from 0
   to 1
It could also have the syntax specific to generate music notes or even
instruments.
maybe something like this
sound {
   note "c"
   from 0
   to 0.5
sound {
   note "A"
   from 0.5
   to 1
I am missing other info such as tempo, bit rate, and all stuff related
to sound.
I am not very familiar with sound theory. But that is more or less the idea.
I think a good idea would be to create another language with povray
syntax and the extra syntax for the sound. Then create a sort of
compiler for the language that generates povray files for the animation
side and nyquist (a music description language) files for the music side.
Wouldn't that be cool?
All the best
Fidel.
Subject: Re: complete animation language
Date: 25 Mar 2003 11:16:42
Message: <3E8080E9.10101@free.fr>
Just my 2 (euro) cents, but I guess it makes no sense
to merge sounds at the time the images composing the animation
are calculated. Just think of what is done in video editing:
the soundtrack is always added after the film edit because
otherwise you would end up with non-linear music score each
time there's a scene cut.
Date: 25 Mar 2003 12:53:16
Message: <3e80978c@news.povray.org>
Another idea: as POV-Ray generates synthetic images/animations. What POV-Ray
like program would generate synthetic sounds?
Date: 25 Mar 2003 13:35:14
Message: <Xns9349C70E795B1raf256com@204.213.191.226>
"Apache" <apa### [at] yahoocom> wrote in
news:3e80978c@news.povray.org
> POV-Ray like program would generate synthetic sounds?
Hmm.. imho this could be grate - take from POV - CSG, shape definitions
etc, and add to material another property - sound - that defines how object
is reflecting sound (or diffusing it).
I.e. :
// mettal pipe
cylinder { -z,+z, 0.1 sound { reflection .5 } }
// echo chamber
box { -1,+1 inverse sound { reflection .3 } }
// carpeted holway
box { -1,+1 inverse sound { diffuse .75 } }
Sound can be interpreted like a special type of... wave, and therefore it
can be traced just as light do :
light-ray-tracer => wave-ray-tracer
light_source => sound_source
diffuse => sound { diffuse }
reflection => sound { reflection } - makes echo
etc...
Date: 25 Mar 2003 14:36:40
Message: <3e80afc8$1@news.povray.org>
the closest thing i can think of would of course be csound
( http://www.csounds.com/ ).  it also uses some kind of
"scene description language" (or "sound ~", for that matter),
and runs on many platforms.
i have already used it to create sounds for povray animations,
where the sources for both povray and csound were generated
by a perl skript, then rendered, and the outputs put together
in adobe premiere.
IMHO there is really no need to integrate those two things,
as they already cooperate smoothly that way.
g.
"There are still places where people think that the function
of the media is to provide information." -- Don Rottenberg
++++++++++++++++ http://www.psico.ch/ ++++++++++++++++
Date: 26 Mar 2003 03:48:06
Message: <3E816758.7070507@nodomain.com>
I guess I didn't explain myself here. Well, what I meant was to merge
the two languages into one, which would be pre-processed by another tool
and generate a povray file for the animation and another file let's say
csound or nyquist for the music. It would be useful to compose the sound
  tracks for your movie since you know the timing. But obviously it
would be great for guys that love coding cause most guys use cubase or
other visual software.
It would be cool to design the sound together with your animations cause
you would know the timming for both the movie and the sound track.
Then you just put it together with a film editor.
This of course is if you do your complete animation in povray. Without
extra transitions that you may add later on your editing software. I
have seen a lot of animations whose transitions were all made in povray.
Take John Vansickle, for instance, he does all his transitions in povray.
All the best
Fidel.
Date: 26 Mar 2003 03:48:59
Message: <3E81678E.5070403@nodomain.com>
There is nyquist (a lisp like programming language) or csound (a c like).
All the best
Fidel.
Date: 26 Mar 2003 14:49:07
Message: <cjameshuff-1FA797.14493526032003@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
Wrong. POV does not simulate the wave nature of light. It can get away
with a pure particle simulation because the wavelengths of light are so
small, so the effects are usually invisible or unnoticed. There are
special cases where wave effects are faked, like iridescence or
dispersion, but overall POV treats light as particles with RGB
intensities.
Sound has a much larger wavelength (for example, a 5 KHz sound in normal
conditions has a wavelength of about 7cm, 500Hz about 0.7m) and travels
at a much lower speed, so effects such as lag time and diffraction have
much greater importance. Raytracing techniques may have some application
in sound simulation (though I doubt it), but you would want a program
designed from the start for it.
http://tag.povray.org/
Date: 26 Mar 2003 22:24:48
Message: <3e826f00@news.povray.org>
Not quite an "idea"... Such a program does exist -- for many, many, many
years. Has its own community, lots of unoficial versions (I made one some 5
years ago..:-), etc.:
Canonic version is here:
  http://www.cs.bath.ac.uk/~jpff/dream.html
I havn't used it for many years... and now it seems like it wasn't updated
for quite a while. The mainteiner used to be John ffitch, but the notes for
the latest version contain some other guy's name... Strange.
