POV-Ray : Newsgroups : povray.programming : POVMS Server Time
12 Jan 2026 08:48:00 EST (-0500)
  POVMS (Message 1 to 9 of 9)
Subject: POVMS
Date: 12 Nov 2002 06:41:37
Message: <3DD0E8F0.42432B09@web.de>
Hi there,
I'm new to povray programming and want to do a parallel version of
povray using MPI and perhaps Multithreading. I had a short view on the
source code and I saw this POVMS/COOPERATE stuff (I do not fully
understand what its purpose is) May it be useful for me??? If so, can
anybody tell me about the main concept? All the parallel versions of
povray I have seen work oonly with version 3.1, which doesn't have this
stuff... so I can't copy :(
Thanks,
Matthias
Subject: Re: POVMS
Date: 12 Nov 2002 07:01:57
Message: <3dd0edb5$1@news.povray.org>
In article <3DD0E8F0.42432B09@web.de> , Matze <mat### [at] webde>
wrote:
> COOPERATE
This has been there in previous versions as well.  POVMS has absolutely
nothing to do with multithreading at all.  That should be fairly clear from
the source code...
    Thorsten
e-mail: tho### [at] trfde
Subject: Re: POVMS
Date: 12 Nov 2002 07:57:30
Message: <3DD0FABA.FB6344F6@informatik.fh-fulda.de>
> wrote:
> > COOPERATE
Ok, you're right and I also figured out what it is...
> the source code...
you say that because you wrote it... I also know what it does(basically), it's
about passing messages. But just because I'm curious: for what is it
used/should it be used (it is disabled now)?
The source code doesn't tell me that...
Matthias
Subject: Re: POVMS
Date: 12 Nov 2002 08:07:50
Message: <m1v1tuo9mm76ltqrnensvt84nsenr7hhne@4ax.com>
On Tue, 12 Nov 2002 13:57:30 +0100, Matthias Fueller
IIRC it was partially explained in the thread 'Proposal for 4.0 ...' one month
ago in this group.
ABX
Subject: Re: POVMS
Date: 12 Nov 2002 08:54:53
Message: <3dd1082d$1@news.povray.org>
> absolutely nothing to do with multithreading at all.  That should be
> fairly clear from the source code...
Real programmers dont need comments .....
PGP Public Key
Version: 6.0.417 / Virus Database: 233 - Release Date: 08/11/2002
Subject: Re: POVMS
Date: 12 Nov 2002 10:21:23
Message: <3dd11c73$1@news.povray.org>
In article <3dd1082d$1@news.povray.org> , "Rick [Kitty5]" <ric### [at] kitty5com>
POVMS has plenty of comments...
    Thorsten
Subject: Re: POVMS
Date: 12 Nov 2002 10:23:15
Message: <3dd11ce3@news.povray.org>
In article <3DD0FABA.FB6344F6@informatik.fh-fulda.de> , Matthias Fueller
Well, it is used, just not on the platform's source code you are looking at.
All it is used for is providing an abstraction over POV-Ray text output such
that it can be better used in a GUI...
    Thorsten
Subject: Re: POVMS
Date: 12 Nov 2002 10:27:31
Message: <3dd11de3@news.povray.org>
In article <m1v1tuo9mm76ltqrnensvt84nsenr7hhne@4ax.com> , ABX
> ago in this group.
Well, I don't know from memory, but the source code archive probably also
include a document called "change35.doc", which lists all changes since
POV-Ray 3.5.alpha.1
    Thorsten
Subject: Re: POVMS
Date: 12 Nov 2002 10:33:44
Message: <3dd11f58$1@news.povray.org>
In article <3dd11de3@news.povray.org> , "Thorsten Froehlich"
> POV-Ray 3.5.alpha.1
On Unix it is called "ChangeLog"...
