POV-Ray : Newsgroups : povray.programming : 3.5 src questions Server Time
11 Nov 2025 17:51:34 EST (-0500)
  3.5 src questions (Message 1 to 4 of 4)
Subject: 3.5 src questions
Date: 2 Oct 2002 03:09:18
Message: <3D9A9B12.70DC2D1E@nospam_zip.to>
In Parse_Cylinder in parse.cpp
        Parse_Vector(Object->apex);  Parse_Comma ();
        Parse_Vector(Object->base);  Parse_Comma ();
should be?
or does the intersection code require this?
It just seems logical that the base of a cylinder from the SDL should be
stored in a variable called base. Of course mathematically it probably
makes little difference. There is similar problem in Parse_Cone.
How have other ppl satisfied the POV licence wrt not enabling new
features unless #version unofficial is in the file?
My matrix math is a little rusty, so can anyone tell if MTransNormal
alters the length of a normal eg through a scale/translate/skew
transform?
This one for someone who is familiar with the hf code: how do I get the
height and normal (possibly smoothed) at a particular **noninteger** x,
z position? Yes I'm stupid.
Bye,
Pabs
Subject: Re: 3.5 src questions
Date: 2 Oct 2002 03:12:12
Message: <3D9A9BC0.72B389B0@nospam_zip.to>
Ooops forgot to ask how to interpolate a prism/lathe/sor spline using a
value in the range 0...1?
I know about Get_Spline_Val, but I think that is only for the spline
functions from the SDL.
Bye,
Pabs
Date: 2 Oct 2002 16:06:44
Message: <chrishuff-0E3E58.16040302102002@netplex.aussie.org>
In article <3D9A9B12.70DC2D1E@nospam_zip.to>,
It makes no difference, but I am surprised...it would seem more
"natural" to specify the base first.
> transform?
I would say "yes". If MTransNormal were used several times on a normal,
all but the last normalization would be redundant and wasteful of CPU.
And I don't remember seeing a normalization in the code. The act of
transforming a normal can change its length, scaling and probably
shearing will do so. Translation has no effect on normals.
Hmm...can't really help there, but I'd look at intersect_pixel(). There
could be a better way to do what you want, more information would help.
http://tag.povray.org/
Date: 3 Oct 2002 01:37:10
Message: <3D9BD63A.253250FC@nospam_zip.to>
Thanks for the tips Chris
Bye,
Pabs
