POV-Ray : Newsgroups : povray.programming : Two minor things in the source Server Time
11 Jun 2026 18:28:29 EDT (-0400)
  Two minor things in the source (Message 1 to 3 of 3)
Subject: Two minor things in the source
Date: 9 Aug 2002 10:41:36
Message: <3D53D4A0.5701F879@gmx.de>
parse.h, line 624:
  LAST_TOKEN
#ifdef GLOBAL_PHOTONS
  GLOBAL_TOKEN,
#endif
defining GLOBAL_PHOTONS would lead to an error, it would probably be good
to place LAST_TOKEN after all #if's.
parse.cpp, line 3307 and 3408:
"triangle triangle mesh data"
should probably be:
"temporary triangle mesh data"
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: Two minor things in the source
Date: 9 Aug 2002 10:49:30
Message: <5bl7luc4d5i547hc8am47857b45o292ei5@4ax.com>
On Fri, 09 Aug 2002 16:41:36 +0200, Christoph Hormann <chr### [at] gmxde>
wrote:
> parse.h, line 624:
>  LAST_TOKEN
>   GLOBAL_TOKEN,
> #endif
I have noticed this too and wondered why things like this are present at all.
Or #if 0 things.
> should probably be:
That's not the only occurance. Look for "all all", "the the". Is this some
english construction I never met earlier or some mistake in automation ?
ABX
Date: 9 Aug 2002 19:15:47
Message: <chrishuff-F8E120.18055909082002@netplex.aussie.org>
In article <5bl7luc4d5i547hc8am47857b45o292ei5@4ax.com>,
> Or #if 0 things.
They are commented or disabled with #if 0 because they are not fully
functional. They are present because they are works in progress and the
code that is there might be useful, there would be little benefit in
going through the source and removing them for the official release..
It's a mistake. No idea how it happened though.
http://tag.povray.org/
