POV-Ray : Newsgroups : povray.programming : Adding a new object Server Time
11 Jul 2026 16:58:49 EDT (-0400)
  Adding a new object (Message 1 to 10 of 17)
Subject: Adding a new object
Date: 3 Aug 2002 02:34:02
Message: <3D4B7962.DF754423@hotmail.com>
There are a couple of primitives I'm thinking of suggesting for V4.
Since I'd like to do all the legwork for implementing these primitives
(writing the ray intersection tests, automatic bounding calculations,
etc), so that the suggestion will put less work on the POV-Ray team,
excatly what functions are needed to fully support a primitive
under POV-Ray?
John
Subject: Re: Adding a new object
Date: 3 Aug 2002 06:31:43
Message: <3d4bb10f@news.povray.org>
> under POV-Ray?
  Would it be possible for you to mention which types of primitives are
you thinking about?
Date: 3 Aug 2002 17:01:49
Message: <chrishuff-BE646E.15523903082002@netplex.aussie.org>
In article <3D4B7962.DF754423@hotmail.com>,
> under POV-Ray?
Well, POV 3.5 uses methods that compute the normal, insideness of a
point, all intersections with a ray, UV coordinates, copy/destroy the
shape, invert the shape, and the various transformations (translate,
rotate, scale, and transform). There are also functions for creation and
computing bounding boxes, and sometimes others. Make a 3.5 patch and it
shouldn't be too hard to adapt for 4.0, but it is likely you would have
to rewrite most of the code, and there could be very different
requirements.
Going to give any hints as to what you are planning? ;-)
Date: 5 Aug 2002 14:46:53
Message: <3D4EC82C.C892E71F@hotmail.com>
> are you thinking about?
Two rather ambitious ones:
First, incorporate quadrilaterals into the mesh object.  This would
make polygon modelling simpler.
Second, a recursive object (ie, a fractal).
John
Date: 5 Aug 2002 17:43:51
Message: <chrishuff-D1FC98.16334605082002@netplex.aussie.org>
In article <3D4EC82C.C892E71F@hotmail.com>,
That wouldn't really be a primitive, just an addition to the mesh
syntax. Probably quite easy, just look at how it parses triangles and
add code to parse a quad instead, splitting it into two triangles to add
to the mesh.
Like an L-system? That would be very interesting...I haven't done
anything with them. Not sure how useful it would be though.
Date: 6 Aug 2002 03:33:49
Message: <3d4f7bdd@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
Why not just script one?
...Chambers
Date: 6 Aug 2002 10:51:07
Message: <3D4FE2EF.8010907@free.fr>
> to the mesh.
Why stop at the quadrilateral, let's have also a plain polygon
(no hole) in the mesh parser (while still storing only triangles).
Then handling the quadrilateral is just a subcase of the generic polygon.
Date: 6 Aug 2002 12:57:16
Message: <chrishuff-D43982.11471206082002@netplex.aussie.org>
In article <3d4f7bdd@news.povray.org>,
Simple: slow parsing. Since POV 4.0 will probably use a VM for the
language, that isn't such a big deal for the future.
Date: 6 Aug 2002 15:02:46
Message: <3D501D67.23725A51@hotmail.com>
To allow memory to be saved (at the expense of rendering speed, but
some people would welcome that).
John
Date: 6 Aug 2002 15:07:30
Message: <3D501E84.99B8A6AD@hotmail.com>
> > and add code to parse a quad instead, splitting it into two
> > triangles to add to the mesh.
> polygon.
I was actually thinking of storing the quads as quads, internally,
on the guess that they can be optimized to the point that they render
faster than the two triangles that would replace each.
Maybe not.
I'm also working on my subdivision surface macros, and have found a
way to extend the Loop surface to support quadrilaterals in addition
to triangles; hence my interest in adding that to the mesh.
John
