POV-Ray : Newsgroups : povray.programming : how to do within an animation? Server Time
11 Nov 2025 19:51:19 EST (-0500)
  how to do within an animation? (Message 1 to 2 of 2)
Subject: how to do within an animation?
Date: 26 Apr 2002 14:41:13
Message: <3CC99F62.1CCC1EC4@pandora.be>
Starting with a box I want to take away some parts of it, the one after
the other (using the difference of the box and the union of the parts,
at each step one part more). After each step I want to save the
resulting image. I suppose it can be done using an animation. But how
can I count the steps in the animation?
Or: does "clock" get a numerical value if one knows that clock varies
from 0 to 1 and that the number of images in the animation should be ex.
11).
Herman Serras
Gent (Belgium)
http://cage.rug.ac.be/~hs/
Subject: Re: how to do within an animation?
Date: 26 Apr 2002 14:58:27
Message: <3cc9a353@news.povray.org>
"Herman Serras" <Her### [at] pandorabe> wrote in message
news:3CC99F62.1CCC1EC4@pandora.be...
> 11).
Short:Yes
Not as Short: The clock, by default goes from 0 to 1, interpolated over the
number of frames (i.e. clock value = frame_number*1/#frames) . If you have
cyclic animation turned on you would basically add 1 to the number of frames
(clock =  frame_number*1/(#frames+1)).  You can also override the defaults
for clock but setting Initial_Clock and Final_Clock in the .ini, the clock
variable is then interpolated between these two numbers in the same fasion.
If you use 3.5, there is the "frame_number" variable that will return the
actual frame number in your scene rather than "clock"
Hope that answers your question
-tgq
