POV-Ray : Newsgroups : povray.programming : optimizing / 3dnow Server Time
15 May 2026 22:26:09 EDT (-0400)
  optimizing / 3dnow (Message 1 to 4 of 4)
Subject: optimizing / 3dnow
Date: 16 May 2001 03:27:43
Message: <3B022C14.C6D41740@smileyface.com>
Hi there.
I've been playing with the POV source for two weeks or so, looking for
happy things I could do with 3dnow.  Judging by some horribly calculated
benchmarks and a few passes through CodeAnalyst:
I think you might be able to get about a 4% speed increase by using
3dnow for color operations.  Not everywhere mind you, a small chunk of
3dnow in the middle of floating point code is a bad thing.
There seems to be a similar increase from simply aligning COLOURs to 8
bytes by padding them to 6 elements rather than 5.  This would of course
backfire on large scenes that don't fit in memory.  (If it's not just a
hallucination :)
Some parts of the BBox code might benefit from 3dnow.  Check_And_Encode
seems to be used a lot (iirc, around 10% cpu time in my tests), and
afaict isn't hurt by using single precision.  'Course I can't say I
really understand it, so what do I know? ;)
I was also puzzled by the following from the area light code:
            New_v1 = (int)ceil  ((v1 + v2)/2.0);
            New_u2 = (int)floor ((u1 + u2)/2.0);
I'm having a hard time seeing why floating point functions were even
considered here.  All the variables involved are ints.  Is there some
condition where this is diffeent from this?:
            New_v1 = ((v1 + v2 + 1) / 2);
            New_u2 = ((u1 + u2) / 2);
I don't think it makes much of a difference time-wise, but it just seems
very strange to me.
Some other things from my early, naive attempts: with all single prec
math (DBL = float) it can't even parse scenes properly, and with all
VECTORs as single prec, x and y are not perpendicular.  (could probly be
fixed by changing some #defines, but in retrospect, I doubt it would be
a good idea)
Just thought someone might find this interesting.
-josh
Subject: Re: optimizing / 3dnow
Date: 16 May 2001 03:48:49
Message: <3B023105.179EA60C@gmx.de>
josh wrote:
> Hi there.
There was already a previous attempt on that:
Subject: 3D!Now
Date: Sat, 27 Jan 2001 11:06:06 +0100
Newsgroups: povray.unofficial.patches
Daniel made a patch, but he did not release it to public.  It uses some
MS-Compiler specific things for implementation.  I recently contacted him
on that, but i got no reply.
There was quite some discussion in this and some of the following threads
on portability and other things so you might want to read it.
Date: 23 May 2001 13:50:54
Message: <3B0BF8CD.9BE38CBC@smileyface.com>
hmm, thanks.
I would look at that except time seems to have started in february, no
matter how much I argue with netscape.
Ah well, I wasn't planning on pursuing this much further any time soon
anyway.
-josh
> Subject: 3D!Now
> From: "Daniel Jungmann" <DSJ### [at] gmxnet>
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 23 May 2001 14:26:57
Message: <3B0C0119.47CB2490@gmx.de>
josh wrote:
> hmm, thanks.
You should check
Edit -> Preferences -> Mail&Newsgroups -> Disk Space
and try reloading afterwards.
